C-Hook, Lathe tools (insert and holders)
I use a C-Hook DLL for transfer tool data into mastercam tool manager.
For mill and drill tools all works fine. If I put lathe tool I have a problem about the insert and holder structure in LATHETOOL.
Can you explain me the following attributes:
sHolder.szShape;
sHolder.szInsShape[MAX_INSERTS]
sHolder.nShape
For example szInsShape=TRCDV
Can you please explain me these value ?
How is the relation between sInsert.szShape and
Holder sHolder.szInsShape and sHolder.szShape ?
How can I calculate the right sHolder.nShape ?
thanks.
Keta,
Here is what I go from Programming...
INSERT.szShape –> character string containing valid insert shape codes for the shape. (e.g. T-riangle, C-55 deg diamond, D - 80 deg. diamond, etc.)
INSERT.nShape –> index into szShape array for the currently defined insert’s shape
sHolder.szShape & nShape –> work the same as for the INSERT structure
sHolder.szInsertShape –> character string containing shape codes for inserts that can be used with this holder. This controls the filtering in the GUI.
The szShape & szInsertShape arrays should NOT be changed from their default values and should be treated as constant. I can’t exactly predict how the software will behave if they are altered, but I’ll bet compatibility with existing MCX files and tool libraries would be broken.
Is this a sufficient answer?
