VB-Mcleads does not take in Arcradius Value
Hi, I wrote a VB program to automatically chain the contour with leadin and leadout values.
In the program, I give the values of the leadin and leadout values for both lines and arcs. After running & chaining a contour, I see, from the "Operation Manager", that it only takes in the values for lines and also Arcsweep, but no ArcRadius (which remain zero no matter what I do, even if I give a specific value like, Leadin.ArcRadius =.1).
Can anybody point out if there is something wrong in my program or there is a bug in VB that prevents it importing the ArcRadius value.
To test, make a chain on any lines or closed shape and check the result in "Operations Manager". When done. double-click the "Parameters", and then click "leadIn/Out" to see if there is value in "Radius" part (should be non-zero).
Thanks for helping
Kevin Qian
'Apt_test
Call Main()
sub Main()
Dim tool_dia
Dim leadin
dim leadout
tool_dia=.3125
AskForChain("chain please")
Set leadin = New McLeads
leadin.Useline = 1 'Use a line For leading In/out
leadin.LineLength = tool_dia/2 'leadin length
leadin.LineTangent = 1 'Is the line Tangent Or Perpendicular?
leadin.LineRampHeight = 0 'Height of lead In/out Line (defining a ‘ramp’)
leadin.UseArc = 1 'Use an arc For leading In/out
leadin.ArcRadius=tool_dia/2 'Radius of lead In/out arc, **** NOT WORKING, ArcRadius does not take any value ****
leadin.ArcSweep = 1.57079633 'Angular sweep of lead In/out arc, 1.57079633 works out to be 90 degree
leadin.ArcHelixHeight = 0 'Height of lead In/out Arc (defining a helix
set leadout = new mcleads
leadout.UseLine = 1
leadout.LineLength = tool_dia/4
leadout.LineTangent = 1
leadout.LineRampheight = 0
leadout.UseArc = 1
leadout.ArcRadius=tool_dia/4 'Radius of lead In/out arc, **** NOT WORKING ****
leadout.ArcSweep = 1.57079633
leadout.ArcHelixHeight = 0
Call SetEntry(0,0,leadin) '1st zero for mid pt of contour, 2nd zero for overlap
Call SetExit(leadout)
Call MakeContour("",tool_dia,0,0,mctool_flat,mcCUTTER_COMP_LEFT,mcCUTTER_ROLL_SHARP,100)
end sub
