Mastercam VB Script Function Question
I am new to mastercam and looking for ways to create setup sheets and tool lists.
I tried the sample VB Script "GETJOBINFORMATION.VBS" but it did not report all values.
I need the GetToolDiameterOffsetNumber(ToolNumber) function but it returns only zero.
The GetToolName(ToolNumber) function returns "TOOL N/A".
I think these values are in my .MCX file because they output in my post.
I have included sample code below, what am I doing wrong?
My reseller says they do no support VB and to try posting here.
Call Main()
Sub Main()
'Dim intOperations, intOpCount,
Dim nOpID
Dim ToolNumber
Dim tdon
Dim tnam
' get the id of the first operation
nOpID = GetFirstOperationID("")
Do
' get the tool number using the current operation
ToolNumber = GetToolNumberFromOperationID("", nOpID)
ShowString(nOpID & " ToolNumber: " & ToolNumber)
tdon = GetToolDiameterOffsetNumber(ToolNumber) 'Get the tool diameter offset number of a tool
ShowString(nOpID & " Tool Diameter Offset Number: " & tdon)
tnam = GetToolName(ToolNumber)'Get the tool file name of a tool
ShowString(nOpID & " Tool Name: " & tnam)
nOpID = GetNextOperationID() ' get the next operation's id
Loop While(nOpID <> -1)
End Sub
Our dealer contacted Mastercam. Their response is below.
_______
I did a quick look at this and it appears that this is a bug in the VBScript API in Mastercam.
If you run this script on a part file with multiple operations it will report the correct information on all of the operations, except for one.
(I get the same result with X4-MU3 as I do with X5)
For your reference, this issue has been logged as #00088663
_____________
FYI...
The issue in the script code you posted is really within these (2) functions ->
GetFirstOperationID
GetNextOperationID
The GETJOBINFORMATION.VBS does not use these functions, as it iterates thru the operations using a different method -
which works, except there is a minor bug in that vbs! :angry:
To correct GETJOBINFORMATION.VBS, change this "For" statement to read ->
' -- Iterate all operations
For intOperations = 0 To intOpCount-1
You should be able to use the same logic for looping thru the operations used in GETJOBINFORMATION.VBS in your Script. ->
' -- Get operation count
intOpCount = GetOperationCount(vbNullString)
'Do whatever...
Next
Thank you for replying...
I adjusted the loop counter to start at zero as you mentioned.
I changed the operation number display to start at 1.
I loaded a mill .MCX file and GetJobInformation.vbs worked with the corrections you mentioned.
I do get the problem with my lathe .MCX files.
When using a lathe .MCX file the tool numbers and operation comments display correctly.
The remaining values however do not display correctly for a lathe.
I was able to add case statements to catch the lathe operation types.
I would appreciate you pointing me in the right direction.
Thanks again
  • 2 weeks later...
