Edit Mpmaster for drill cycle Mazak
Hello,
we are using the Mpmaster for our MAZAK CNC Maschines.
In the drill cycles G82, G83 and G73 you have the possibilty to reduce the feedrate at a distance from the hole ground in percent.
How can i edit the post, that i have these values in my drill cycles ?
I've attached the description from the handbook, so you can see how it have to output the G-Code.
Dreas
G73.pdf
G82.pdf
G83.pdf
In the Control Definition of your machine, edit the Text/Mill Drill Cycles associated with each G code to replace certain variables with the ones you need, ie, Feed Ovr Distance (I) and Feed Ovr % (J).
Once this is done, edit the post block for each type of G-code and associate the obtained value entered in the drill cycle dialog box.
And voilà!
Cheers!
Luc
