Post Help
Using MpMaster post for Fanuc vertical. If a make a toolpath in top view it doesn't rotate the rotary to A0.0, I want to add an A0.0 in to make sure it's where it is supposed to be. How do i do it??
(THIS)
T1 ( 1/2 DRILL)
M6
(MAX - Z.2)
(MIN - Z-.2)
G0 G17 G90 G55 X-2.626 Y-2.297 S1200 M3
G43 H1 Z.2
G94
(TO THIS)
T1 ( 1/2 DRILL)
M6
(MAX - Z.2)
(MIN - Z-.2)
G0 G17 G90 G55 X-2.626 Y-2.297 A0.0 S1200 M3
G43 H1 Z.2
G94
Hi
If you want it to be done automatically inside the post look for this line to not have a pound sign (#) in front of it
pwrtt$      # Write tool table, scans entire file, null tools are negative
          if rotaxis$ > 0 | rotary_type$ > 0 | mill5$ <> 0,
            sav_rot_on_x = rot_on_x
            output_z = no$
          if vmc = 0 & tlplnno$ <> 2, sav_rot_on_x = rot_on_x
          if vmc = 1 & tlplnno$ > 1, sav_rot_on_x = rot_on_x
          sav_rot_on_x = rot_on_x    #Uncomment this line to output rotary axis value even when it's not used     <<<---------
          t$ = wbuf(4,wc4)        #Buffers out tool number values
          if tool_table = 1, ptooltable
          if tool_table = 2, ppredtool
          if tool_table = 3, pmetatool
          if t$ >= zero, tcnt = tcnt + one
          ptravel
          pwritbuf5
This should do the trick.
