spindle startup in wrong place
I am running a mori seiki sl403 lathe with mastercam x5 lathe 1. Right now I have to move the g97 s600 m13 line above the first rapid move everytime it posts or I get alarms at the machine. I would like to change that. Here is an example of how it is now and Where I would like to be.
now
(TOOL - 7 OFFSET - 7)
( 1/2" X 90 DEG SPOTDRILL)
P3000
(SPOT 3/8"-16)
G54
N1 T0707
G98
M45
M69
G0 C-90.
-G0 X2.25 Z.1 M8-
-G97 S600 M13-
G83 Z-.215 R0. F2. M68
C-270.
G80
Z4.
Z.1
M9
M69
G28 U0. W0. C-0. M05
M01
after
P3000
(SPOT 3/8"-16)
G54
N1 T0707
G98
M45
M69
G0 C-90.
-G97 S600 M13-
-G0 X2.25 Z.1 M8-
C-270.
G80
Z4.
Z.1
M9
M69
M01
Where would I look to change this? Also with this same post my rapid moves are feed moves of 500. I would like to see them come out as rapid moves. Is this something in the post or machine def?
You are looking for this section of code in ltlchg$ (and possibly lsof$ if you are using an mplfan based post):
     if css_actv$,
       if css_start_rpm,
         prpm # Direct RPM startup for programmed CSS
       else,
         pcssg50, pcss # NO RPM start - just output the CSS
     else, # Direct RPM was programmed
       prpm # Output programmed RPM
This code will output the rpm value if the tool path is programmed in rpm, or the starting rpm value if programmed in css.
You will need to move this section of code above a line that will look something like this:
     pcan1, pbld, n$, psccomp, *sgcode, pwcs, pfxout, pyout, pfzout,
       pscool, strcantext, e$
The above line is the output for the coordinates and the rapid move. The line in your post may look a little different than this, but should contain the coordinate outputs (pxout, pyout, pzout, pfxout, pfyout, or pfzout) and the gcode call (sgcode)
it looks like that has already been done. this is what I have:
ltlchg$ #Toolchange, lathe
toolchng = one
gcode$ = zero
copy_x = vequ(x$)
pcc_capture #Capture LCC ends, stop output RLCC
c_rcc_setup$ #Save original in sav_xa and shift copy_x for LCC comp.
pcom_moveb #Get machine position, set inc. from c1_xh
c_mmlt$ #Position multi-tool sub, sets inc. current if G54...
ptoolcomment
comment$
if home_type < two, #Toolchange G50/home/reference position
sav_xh = vequ(copy_x)
sav_absinc = absinc$
absinc$ = zero
start_xh = vequ(xh$)
pmap_home #Get home position, xabs
ps_inc_calc #Set start position, not incremental
#Toolchange home position
if home_type = one,
pbld, n$, *sgcode, pwcs, pfxout, pfyout, pfzout, e$
else,
#Toolchange g50 position
pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], "W0.", e$
if home_type = zero, pbld, n$, *sg50, pfxout, pfyout, pfzout, e$
pe_inc_calc #Update previous
absinc$ = sav_absinc
copy_x = vequ(sav_xh)
else,
pbld, n$, pwcs, e$
toolno = t$ * 100 + tloffno$
if not(synch_flg & tool_op$ = 67), #Suppress tool output if cutoff during part xfer
if omitseq$ = 1 & tseqno > 0,
if tseqno = 2, n$ = t$
pbld, *n$, [if home_type = -1, *sgcode], *toolno, e$
else, pbld, n$, [if home_type = -1, *sgcode], *toolno, e$
ipr_actv$ = c1_ipr_actv
pbld, n$, pfsgplane, pfsgfeed, e$
pcaxis_off_l #Postblock for lathe transition
pcom_moveb #Reset machine position, set inc. from last position
pcan
pspindle
#Added for 'css_start_rpm' logic (09/05/01)
if css_actv$,
if css_start_rpm,
else,
if home_type > one, absinc$ = zero
pcan1, pbld, n$, *sgcode, pfxout, pyout, pfzout, pscool, strcantext, e$
if lcc_cc_pos, plcc_cc_pos #Use sav_xa to position with comp. LCC
pcom_movea #Update previous, pcan2
ps_inc_calc #Reset current
if css_start_rpm,
pcssg50, pcss # CSS output AFTER a G97S???? RPM spindle startup
c_msng$ #Position single-tool sub, sets inc. current if G54...
toolchng = zero
plast
Sorry, I missed that this is actually a milling operation. The change needs to be in the mtlchg$ post block, not the ltlchg$. pspindle and prpm need to be moved above the coordinate output as shown below:
     pcaxis_on_m   #Postblock for mill transition
     pcan
     pbld, n$, pclampoff, e$        # Unclamp
     protretinc                        #Zero out the C-axis then redo the coordinate calculation
     pcom_moveb
     if millcc, pbld, n$, *sgcode, "C0.", [if y_axis_mch, "Y0."], e$
     else,
       prv_gcode$ = c9k                  #change modality for forced output
       pbld, n$, `sgcode, pfcout, e$     #` used in case indexing mode
     pindex
     pbld, n$, pclampbrake, e$  # Clamp
     pspindle
     prpm
     pcan1, pbld, n$, *sgcode, pfxout, pyout, pfzout, strcantext, e$
     pbld, n$, pscool, e$
In the control definition, if you go to the feed page, there's a check box for convert rapid to maximum feed. If the box is checked, uncheck it and that should fix it up for you. Make sure you check both the mill and lathe feed pages for this.
To get in go through settings, machine definition manager, then select the control definition. This will ensure that the changes stick.
If this is not checked, let me know and we can walk through other options.
