MITS MELDAS 600 CONTROL
surelink
We have a OKK with a Mits Meldas 600 control, all of our other OKK have the Fanuc control. We use the same MPFAN post on all. The problem is the Mits will get an error if we use the Rigid Tap Cycle. If we manualy change the feedrate from F to a E it will work. Is there a work around where we do not have to edit the nc file?
  • 2 weeks later...
Why does everybody call something they don't know how to do a work around?
You can do one of 2 things to change the code for a "different" machine.
1. You could set up a post question that will change the format variable to output for your "different" machine
2. You could make a second post that just handled the change, giving you a different post for a "different" machine
It's not a work around, "YOU" have a different machines with different needs.
What I was looking for is maybe a parameter setting recommendation for the Mits control to allow it to use the same rigid tap code as the Fanuc post. We have created a custom drill cycle to cure this. Sorry I upset you so much. I will try to be more considerate in the future.
