Need post to put retract point at end of every block in drill can
Tricky question??
I have been trying to tweek a post processor to post codes for a a2100 control on a tree mill. the machine likes the drilling cycles to all use g83 with a j1 for no peck, a j2 for peck full out w/ k value, and a j3 for peck full out w/ k value and decrease peck by i value all canned cycles use w.? i.e w.1 for the retract point and it must be put in each block. so an example of ideal program is right hear.
The main problem is the $ symbol and space between W.1
I have done a ton of editting so far to get to this point. It started as a purely fanuc flavored post slightly tweeked for a fadal with 32 'E' offsets. there now 'H' offsets. i removed all tool offsets and have got the drilling cycles this far. im just an amature programmer with 3 years of mastercam and gibbs under my belt 4 years of writing g code by hand as well. This is celarly the logical step to undertake.
Im sure we all could trade knowledge on this thread, it is an interesting question in my opinion. Any help would be greatly apprecieated.
Rory C.
N10 O0000 ( T )
N20 ( CREATED ON 12-16-12 AT 8:17 PM )
N30 ( MCX FILE - C:\MCAMX\MCX\T.MCX )
N40 ( NC FILE - C:\MCAMX\MILL\NC\T.NC )
N50 ( MATERIAL - ALUMINUM INCH - 2024 )
N60 G0 G20 G17 G40 G80 G90 H0 Z0.
N70 G28 X0. Y0. Z0.
N80 ( .5 DRILL TOOL - 62 DIA. OFF. - 62 N80 ( TREE_VMC_1260_#96_3_AXIS_MILL )
N90 ( MACHINE GROUP-1 )
N100 T62 M6
N110 M7
N120 G0 G90 S2139 M3 H20 X1. Y1.
N130 Z1.5
N140 G83 X1. Y1. Z-1.0002 J1 W01.5 F4.11
N150 Y9. w1.5
N160 X9. w1.5
N170 Y1. w1.5
N180 G80
N190 ( TREE_VMC_1260_#96_3_AXIS_MILL )
N200 ( MACHINE GROUP-1 )
N210 X1. Z.1
N220 G83 Z-.7502 J2 W0.1 K0.1 F4.11
N230 X9. Y9. w.1
N240 X1. w.1
N250 X9. Y1. w.1
N260 G80
N270 ( TREE_VMC_1260_#96_3_AXIS_MILL )
N280 ( MACHINE GROUP-1 )
N290 X1.
N300 G83 Z-1.0002 J3 W0.1 K0.5 I0.1 F4.11
N310 X9. Y9. w.1
N320 X1. w.1
N330 X9. Y1. w.1
N340 G80
N350 M09
N360 M5
N370 G90 H0 Z0.
N380 H0 X0 Y0
N390 M02
i am currently with this
N10 O0000 ( T )
N70 G28 X0. Y0. Z0.
N100 T62 M6
N110 M7
N130 Z1.5
N150 Y9. w$ 1.5
N160 X9. w$ 1.5
N170 Y1. w$ 1.5
N180 G80
N210 X1. Z.1
N230 X9. Y9. w$ .1
N240 X1. w$ .1
N250 X9. Y1. w$ .1
N260 G80
N290 X1.
N310 X9. Y9. w$ .1
N320 X1. w$ .1
N330 X9. Y1. w$ .1
N340 G80
N350 M09
N360 M5
N370 G90 H0 Z0.
N380 H0 X0 Y0
N390 M02
my drilling section in the post looks like this
# Drilling
pdrill0$ #Pre-process before drill call
sav_dgcode = gcode$ #Capture gcode for 5 axis drill
pdrlcommonb #Canned Drill Cycle common call, before
if initht$ <> refht$, drillref = zero
else, drillref = one
if sav_dgcode =81,
result = newfs(two, zinc)
if drillcyc$ = three | drillcyc$ = 7, drlgsel = fsg1(-ss$) + drillcyc$ * two
else, drlgsel = fsg2(dwell$) + drillcyc$ * two
prv_refht_a = c9k
prv_refht_i = c9k
prv_dwell$ = zero
prv_shftdrl$ = zero
if cuttype = three, sav_dgcode = gcode$
else, z$ = depth$
if cuttype = one, prv_zia = initht$ + (rotdia$/two)
else, prv_zia = initht$
pcom_moveb
feed = fr_pos$
comment$
pcan
#5 axis must map the true Z, correct Z calculation here
if cuttype = three,
prv_zia = zabs + (-depth$) + initht$
zia = fmtrnd(zabs)
zinc = zia - prv_zia
prdrlout #R drill position
if cuttype = one, refht_a = refht$ + (rotdia$ / two)
else, refht_a = refht$
refht_i = refht$ - initht$
#refht_i can never be positive (pg 4-4)
if refht_i > 0, refht_i = refht_i * -1.
if cuttype = three, refht_a = w$
if absinc$ = zero, refht_a, !refht_i
else, refht_i, !refht_a
pdrill$ #Canned Drill Cycle - G81/G82
pdrlcommonb
pcan1, pbld, n$, *sgdrill, *sgdrlref, pfxout, pfyout, pfzout, 'J1', pcout,
prdrlout, dwell$, *feed, strcantext, e$
pcom_movea
ppeck$ #Canned Peck Drill Cycle
pdrlcommonb
pcan1, pbld, n$, *sgdrlref, *sgdrill, pfzout, 'J2', pcout,
prdrlout, *peck1$, *feed, strcantext, e$
pcom_movea
pchpbrk$ #Canned Chip Break Cycle
pdrlcommonb
pcan1, pbld, n$, *sgdrlref, *sgdrill, pfzout, 'J3', pcout,
prdrlout, *peck1$, *peck2$, *feed, strcantext, e$
pcom_movea
ptap$ #Canned Tap Cycle - G84/G74
pdrlcommonb
feed = (1 / n_tap_thds$) * speed
pcan1, pbld, n$, *sgdrill, *sgdrlref, pfxout, pfyout, pfzout, pcout,
prdrlout, *feed, strcantext, e$
pcom_movea
pbore1$ #Canned Bore #1 Cycle - G85/G89
pdrlcommonb
pcom_movea
pbore2$ #Canned Bore #2 Cycle - G86
pdrlcommonb
pcom_movea
pmisc1$ #Canned Misc #1 Cycle - G76
pdrlcommonb
prdrlout, shftdrl$, dwell$, *feed, strcantext, e$
pcom_movea
pmisc2$ #Canned Misc #2 Cycle - G84.1/G74.1
pdrlcommonb
prdrlout, *tap_speed, *feed, e$
pcom_movea
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
if drillcyc$ = 8, pdrlcst8
else,
pdrlcommonb
sopen_prn, "CUSTOMIZABLE DRILL CYCLE - NOT CONFIGURED - FIRST HOLE", sclose_prn, e$
pcom_movea
pdrlcst8 #Custom drill cycle 8 - example custom cycle
pdrlcommonb
sopen_prn, "CUSTOMIZABLE DRILL CYCLE EXAMPLE - FIRST HOLE", sclose_prn, e$
pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
pcom_movea
# Additional Holes
pdrill_2$ #Canned Drill Cycle, additional points
pdrlcommonb #causes cordinates to be posted
pcan1, pbld, n$, pxout, pyout, pzout, pcout, *retractpoint$, feed, *w$, strcantext, e$ #format for cordinates # added *w$ by RLC
pcom_movea
ppeck_2$ #Canned Peck Drill Cycle
pdrill_2$
pchpbrk_2$ #Canned Chip Break Cycle
pdrill_2$
ptap_2$ #Canned Tap Cycle
pdrlcommonb
pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, feed, strcantext, e$
pcom_movea
pbore1_2$ #Canned Bore #1 Cycle
pdrill_2$
pbore2_2$ #Canned Bore #2 Cycle
pdrill_2$
pmisc1_2$ #Canned Misc #1 Cycle
pdrill_2$
pmisc2_2$ #Canned Misc #2 Cycle
pdrlcommonb
pbld, n$, sgdrill, sgdrlref, pxout, pyout, pzout, pcout,
prdrlout, speed, feed, e$
pcom_movea
pdrlcst_2$ #Custom drill cycles 8 - 19, additional points (user option)
if drillcyc$ = 8, pdrlcst8_2
else,
sopen_prn, "CUSTOMIZABLE DRILL CYCLE - NOT CONFIGURED - NEXT HOLE", sclose_prn, e$
pdrill_2$
pdrlcst8_2 #Custom drill cycle 8 - example custom cycle
sopen_prn, "CUSTOMIZABLE DRILL CYCLE EXAMPLE - NEXT HOLE", sclose_prn, e$
pdrill_2$
pcanceldc$ #Cancel canned drill cycle
result = newfs(three, zinc)
z$ = initht$
pxyzcout
!zabs, !zinc
prv_gcode$ = zero
pcan
pcan1, pbld, n$, sg80, strcantext, e$
pcan2
You need to format the w$ variable, preferably up in the formatting for the other variables used for drilling. The line you need to insert is something like this:
fmt "W" 1 w$
The 1 may need to be something other than 1, though. My best guess is that you need the same format as the zabs variable, so you might look for the fmt line that formats zabs, which will look something like this:
fmt "Z" 1 zabs
Where the 1 might be a different number.
Glad I could help, but...
Using refht_a will work, too, and might be more correct, if it is the reference height from the drilling dialogue you want, and w$ is the initial height value. However, if it reads
fmt W0 2 refht_a
then you migth not get the correct output, as that means that the value of refht_a is prefixed with "W0". That probably doesn't matter if the value is between 0 and 1, but if that hole is at the bottom of a 1 inch deep pocket, then you would get output of W0-.9 for a retract 0.1 inch above the bottom of that pocket, and I don't think your control will accept that. I think you will need to depete that 0 in the fmt line so it reads
fmt W 2 refht_a
instead.
A piece of general advice when editing drilling cycles in the post processor which many people forget is to also test it for holes where the top of the hole isn't at Z0. Most holes might be at Z0, but not all holes are at Z0, and you don't want to have incorrect output when you think the post processor is working OK.
