bar puller
cell13
I am trying to post a program with bar puller. But not getting correct code. If I take an old program with good bar puller code - delete all operations and geometry, re name file,
re-create geometry and toolpaths and run post I will get good code. I have checked file settings and as far as I can tell I am using the same files for both programs.
On converted program I do not add a bar puller operation, I just do a cutoff ooperation and it posts ok. On new program when I try to add a bar pull operation I get a
warning "Current post-processor does not support toolpaths generated by this function."
I would ask the programmer who made the original program (ya think?) but he is no longer here, so I have to work this out by myself.
Is there a different post he has hidden somewhere? Probably not, I just haven't the experience with lathes that I should have.
Any help will be appreciated.
Thanks (I an only an egg)
  • 2 weeks later...
What Machine? They all like something different.
To keep it simple, this is what I do.
Go to manual entry.
write a bar puller pgm by itself. (one that works).
Save as a file. Look at the bottom of the manual entry box.
Now every time you need it, add the file to the pgm and hand edit the x and z positions as needed. ( you can do that at the machine if needed)
Machineguy
Thanks Machineguy,
Machine is a Haas ST30Y.
I found it in Lathe Cutoff - Toolpath Parameters - Misc. Values, turn off auto set to post values, turn on add bar pull to partoff and turn on parts catcher(Integers), Add distance, Z position and feed rates (Reals).
So easy I couldn't see it.
