NETHook import geometry + operation
Can the NET-Hook API import geometry from another .mcx- file?
Similar to the File Merge/Pattern in Mastercam, but programmatic and also importing operations.
The goal is to import from a library of geometry+operation components and place them within the current file.
The only method I see using the API is
FileManager.Open("Component.mcx-9");
to open a file then read the data I want into memory, reopen the initial file, and add the items to database.
This has drawbacks (I assume it resets the undo stack, for one) and is not sufficient.
An alternate solution is to store component data in a file format I can parse myself. Then read it and create the geometry and operations accordingly. If possible, though, I would prefer to use the API and mcx files.
Currently using C#, developing for Mastercam 9.
The FileManager.Open method has a number of overloads, you can pass in a flag to merge the file with the existing file. The namespace Mastercam.Operations.OperationsManager.ImportOperation allows you to import operations from an external file or operations library. I think that between the two methods you should be able to accomplish what you are after.
Feel free to reply if you need further help.
You could certainly use a layering scheme before hand for your files or implement a scheme for each file you merge and move geometry around.
This example opens the first file and moves everything to level 500, the next file is merged and moved to level 501.
           var file = @"C:\Users\Mick George\Documents\my mcamx9\mcx\T.mcx-9";
            var fileToMerge = @"C:\Users\Mick George\Documents\my mcamx9\mcx\T2.mcx-9";
            // Open
            if (FileManager.Open(false, file, false))
                // Move everthing currently open to level 500
                var geos = Mastercam.Support.SearchManager.GetGeometry().ToList();
                foreach (var geo in geos)
                    geo.Level = 500;
                    geo.Commit();
                // Merge
                if (FileManager.Open(false, fileToMerge, true))
                    // Grab everything not on level 500
                    var allGeometries = Mastercam.Support.SearchManager.GetGeometry().ToList().Where(geo => geo.Level != 500);
                    // Move to 501
                    foreach (var geo in allGeometries)
                        geo.Level = 501;
                        geo.Commit();
            GraphicsManager.ClearColors(new GroupSelectionMask(true));
            GraphicsManager.FitScreen();
Am I calling GetOpGroupDataInExternalFile correctly?
Mastercam.Support.Types.ExternalOpsFileData[] opData = null;
Mastercam.Support.Types.ExternalGroupsFileData[] groupData = null;
bool success = SearchManager.GetOpGroupDataInExternalFile(@"C:\Users\Samuel Hanson\Documents\my mcamx9\mcx\Components\rect.mcx-9", ref groupData, ref opData);
It always returns false.
After much head scratching and another set of eyes on the code I finally determined what the issue was and it has to do with the variable initialization.
Note: You must have a machine group active in Mastercam or this code will still fail. You can either create a machine group prior to thecode or test for an existing machine group.
// This should have the variables initialized to at least one index.
var opData = Mastercam.Support.Types.ExternalOpsFileData[0];
var groupData = Mastercam.Support.Types.ExternalGroupsFileData[0];
