Using mi to set extended offset
I am trying to have the mi variables work to set the extended offset if needed. This is a modified HAAS post.
I have the misc page set up with additional text correctly (see screen shot attached). I can't seem to remember what I need to get the mi5 to output correctly;(
Here is what I have in the post:
if mi4$ = 1, #use extended offset
extoffsetnum = mi5$
"G154 P", extoffsetnum #output extended offset
and here is the output :
N120 T116 M6
N130 G0 G90 G154 P extoffsetnum 10. X2.0359 Y.5566 S6000 M3
N140 G43 H116 Z.25
I would like it to just output "G154 P10" or whatever number is in mi5
Karl
Upon second look, it appears that you were declaring the variable and assigning the value of mi5$ in the same line? If so, you need to keep the assignment, but add a few spaces to get the line away from the far left side.
Anytime a variable is all the way to the left, it is considered a declaration. If you have a fmt statement and a declaration for the same variable, an error will be generated.
Well do what I did for posts years ago.
pwcs		    #G54+ coordinate setting at toolchange
  if workofs$ <> prv_workofs$ | (force_wcs & toolchng > zero),
    if workofs$ >= 0, workofs$ = 54
    if workofs$ = 49, if mprint(swcserror4953, 2) = 2, exitpost$
    if workofs$ = 50, if mprint(swcserror4953, 2) = 2, exitpost$
    if workofs$ = 51, if mprint(swcserror4953, 2) = 2, exitpost$
    if workofs$ = 52, if mprint(swcserror4953, 2) = 2, exitpost$
    if workofs$ = 53, if mprint(swcserror4953, 2) = 2, exitpost$
    if workofs$ > 59, if mprint(swcserror60, 2) = 2, exitpost$
    if workofs$ > 53, #G54 ~ G59 output
	  g_wcs = workofs$
	  *g_wcs
    else, #Extended work offset output
	  p_wcs = workofs$ #P1 ~ P48 output
	  "G54.1", *p_wcs
  !workofs$
swcserror4953   : "ERROR-WORK OFFSET NUMBER SET 49-53 SET TO 54-59 OR 1-48"
swcserror60   : "ERROR-WORK OFFSET NUMBER OUT OF RANGE HIGHER THAN 59 SET TO 54-59 OR 1-48"
With this method you set 54 as G54 and 1 and G54.1 P1 and such. If the person makes an error setting something wrong then they will get a warning to set it correctly.
