Generic post
These are the 5axis settings in the generic 5x post
I think these will give you the results you need
#Assign axis address
str_pri_axis : "C"
str_sec_axis : "B"
str_dum_axis : "A"
#Toolplane mapped to top angle position strings
str_n_a_axis : "A"
str_n_b_axis : "B"
str_n_c_axis : "C"
#Misc. String settings
sopen_prn : "(" #String for Open Parenthesis "("
sclose_prn : ")" #String for Close Parenthesis ")"
sextnc$ : "NC" #String for program extension
#Machine rotary routine settings
mtype : 0 #Machine type (Define base and rotation plane below)
#0 = Table/Table
#1 = Tilt Head/Table
#2 = Head/Head
#3 = Nutator Table/Table
#4 = Nutator Tilt Head/Table
#5 = Nutator Head/Head
head_is_sec : 1 #Set with mtype 1 and 4 to indicate head is on secondary
#Preferred setup is pri. zero matches sec. zero/direction
#Zero machine and determine the planes perp. to axis rotations
#These plane combinations are valid:
#Primary plane XY XZ YZ
#Secondary or XZ XY XY
#Secondary YZ YZ XZ
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1$ = vecx #Zero
rotdir1$ = vecy #Direction
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2$ = vecz #Zero
rotdir2$ = vecx #Direction
