canned text
pcant_out #Canned text - build the string for output
if cantext$ = one, [
pbld, n$, sm00, e$
pbld, n$, "(CLEAN CHIPS)", e$
if cantext$ = two, [
pbld, n$, sg00, "Z6.0", sm09, e$
pbld, n$, sg91, "G28", "Y0.", e$
pbld, n$, sm00, e$
pbld, n$, "(CHANGE CLAMPS)", e$
pbld, n$, sg00, *g_wcs, sg90, pfxout, pfyout,
*speed, sm03, e$
pbld, n$, sm08, e$
if cantext$ = three, [
pbld, n$, "M201", e$
if cantext$ = four, [
pbld, n$, "M200", e$
if cantext$ = five, [
pbld, n$, sm00, e$
pbld, n$, "(ROTATE TO DEGREES)", e$
if cantext$ = 6, [
pbld, n$, sg90, *g_wcs, "X0.", e$
pbld, n$, sm00, e$
pbld, n$, "(LOOSEN AND RETIGHT VISE)", e$
pbld, n$, "( DO NOT OVERTIGHTEN)", e$
if cantext$ = 7, [
pbld, n$, sm51, e$
pbld, n$, "(AIR BLAST ON)", e$
if cantext$ = 8, [
pbld, n$, sm59, e$
pbld, n$, "(AIR BLAST OFF)", e$
#if cantext$ = eleven, [
# pbld, n$, "(OH xxxx)", e$
[canned text]
1. "CLEAN CHIPS - M00"
2. "CHANGE CLAMPS - M00"
3. "AUGER ON"
4. "AUGER OFF"
5. "ROTATE TO DEGREES"
6. "HOME MOVE - RETIGHTEN"
7. "AIR BLAST ON"
8. "AIR BLAST OFF"
9. ""
10. ""
11. ""
Ok I have added these 3 codes but my program adds the mcode m50 and m11 and m07 and m12 and m08 and m13
See program example below.
 if cantext$ =11, [
                                     pbld, n$, "M50", e$
         if cantext$ =12, [
                                     pbld, n$, "M07", e$
        if cantext$ =13, [
                                     pbld, n$, "M08", e$
1. "Stop - M00"
2. "Op Stop - M01"
3. "Bld on"
4. "Bld off"
5. "Dwell - G04 P1"
6. "Chip Conveyor On"
7. "Chip Conveyor Off"
8.
9. ""
10. ""
11. "Bottom Wash - M50"
12. "Thru Coolant - M07"
13. "Flood Coolant - M08"
O0001 (FBM TEST)
(KITAMURA2)
(MACHINE GROUP-1)
(MCX FILE  - \\JPBFS01\COMPANY\COMMONAREA\MIKE STAPLETON\FBM TEST.MCX-7)
(DATE      - APR-02-2015)
(TIME      - 9:23 AM)
(T7   - 10. SPOT DRILL       - H0   - D0   - D0.3937")
N100 G00 G17 G20 G40 G80 G90
N110 G91 G28 Z0.
N120 M50
N130 M11
N140 G90 G53 X0. Y0.
N150 T7 M06 (10. SPOT DRILL)
N160 (MAX - Z1.)
N170 (MIN - Z-.128)
N180 G00 G17 G54 X-7.375 Y-1.5 S329 M03
N190 G43 H0 Z1.
N200 G94
N210 G98 G81 X-7.375 Y-1.5 Z-.128 R.1 F.49
N220 X-4.125 Y-2.
N230 X-.625 Y-1.
N240 G80
N250 M07
N260 M12
N270 X-6.125 Y-2.
N280 G43 H0 Z1.
N290 G98 G81 X-6.125 Y-2. Z-.1181 R.1 F.49
N300 X-2.875 Y-2.
N310 G80
N320 M08
N330 M13
N340 X-5.375
N350 G43 H0 Z1.
N360 G98 G81 X-5.375 Y-2. Z-.1009 R.1 F.49
N370 X-2.125 Y-2.
N380 G80
N390 M05
N400 G91 G28 Z0.
N410 G90 G53 X0. Y0.
N420 G90
N430 M30
It might depend
The canned text section has been slightly reworked since I coded that example, and depending on which post you are using
This is a section out of the new MPMaster
      #Assign string select type outputs
      if cant_pos < three, #cant_pos indicates canned text output
        if cantext$ = three, bld = one
        if cantext$ = four, bld = zero
        #Build the cantext string
        if cantext$ = one, strcantext = strcantext + sm00
        if cantext$ = two, strcantext = strcantext + sm01
        if cantext$ = five, strcantext = strcantext + scant5
        if cantext$ > five,
          strtextno = no2str(cantext$)
          strcantext = strcantext + strm + strtextno
      else, #cant_pos indicates coolant output
        coolant_bin = flook (two, cantext$) #Create binary value for each coolant using lookup table
        if frac(cantext$/two),
          if all_cool_off,
            if coolant_on, pbld, n$, *sall_cool_off, e$
            coolant_on = zero
            suppress = 1               #WBT added this for null toolchange with "First command shuts all off"
                                       #and turn off selected in the second op, post outputs M9 twice
          else, coolant_on = coolant_on - coolant_bin/2 #Odd = off command, subtract appropriate binary value.
        else,                                         #Even = on command
          [   #Determine if this coolant is already on
          local_int = zero
          coolantx = zero
          while local_int < 20,
            result2 = and(2^local_int, coolant_on)
            local_int = local_int + one
            if result2 = coolant_bin, suppress = one
        if suppress <> 1, #Don't output an on code for a coolant that is already on
          if not(frac(cantext$/two)), coolant_on = coolant_on + coolant_bin #Maintain binary sum of all coolants currently on
          coolantx = cantext$ - 50                                          #Create a coolantx value for string select
          pbld, n$, *scoolantx, e$
        suppress = zero
You would need to go in here
        if cantext$ > five & < 11 | cantext$ > 13,            <------------------Modified this line as well
        if cantext$ = 11,    <-----------------------
            Your text
           ]                          Here through here is new code added
        if cantext$ = 12,
            Your text
        if cantext$ = 13,
            Your text
          if all_cool_off,
            coolant_on = zero
          local_int = zero
          coolantx = zero
        suppress = zero
I haven't tested it but it should  be close
If you compare both sections I posted, you'll see the differences....
Let me go back and point them out.....
Which post are you using?  is it new or what vintage is it because canned text has been changed a bit over the years
