Geometry Error
23 minutes ago, x4g said:
There is a new Mastercam Project Template that will create a chook-InteropDll and c# project like what you are used to, this will make it easier to manage your c++ code
How new is this? And where is it?
It looks like I have lost access to the SDK Downloads, C-Hook downloads, and NetHook downloads 🤷‍♂️
9 minutes ago, JKLINE said:
Mastercam::CHookAPI::Database::
This was the key to finding the options/tools/methods ect ect.
I'm still not seeing any 'surface' commands though. Enlighten me?
Ask the Api Team for the relevant chook example to create a ruled/lofted surface, that interface is not exposed to the API
or you can pickup up the definition using the dumplib utility, (see pdf on dumplib in the sdk installer folder)
11 minutes ago, Roger Martin from CNC Software said:
JKLINE,
You are looking to create a Draft surface with a NET-Hook add-in?
Yes.
Take customer geometry
ChainOffsetContour(you've already helped me with this)
DraftSurface(from the Result of ChainOffsetContour) at a negative depth (user specified) and angle (user specified).
All ChainOffsetContour results are closed chains, and climb (Clockwise I think) direction is a positive angle.
On 12/14/2022 at 8:06 AM, JKLINE said:
That's a negative. It's angled at either 10, 15, 20, or 30 degrees at a negative depth.
This here is an example of an end result. White line is the supplied geometry. We offset the green geometry. And then draft a surface down.
White line is customer supplied geometry.
Green is the offsetContour in both directions.
Surface is a draft surface at a negative value.
4 hours ago, Roger Martin from CNC Software said:
JKLINE,
Using the code below, I'm getting a result, but some things seem strange.
1. It doesn't send the surface to a different level.
2. The angle I type in doesn't seem to matter. 15.0 results in -0.2618 degrees.
3. It follows the chains, but not the arcs.
Did I code it wrong? 😕
            void offsetCutchain(){
                SelectionManager.UnselectAllGeometry();
                LevelsManager.RefreshLevelsManager();
                GraphicsManager.Repaint(true);
                var selectedCutChain = ChainManager.GetMultipleChains("Select Geometry");
                int mainGeo = 10;
                  int roughSurf = 138;
                   SurfaceDraftParams roughSurfaceDraftParams = new SurfaceDraftParams {
                    draftMethod=SurfaceDraftParams.DraftMethod.Length,
                    geometryType=SurfaceDraftParams.GeometryType.Surface,
                    length=-0.100,
                    angle=15.0,
                    draftDirection=SurfaceDraftParams.DraftDirection.Defined
                foreach (var chain in selectedCutChain){
                    var mainGeoSide1 = chain.OffsetChain2D(OffsetSideType.Right, .002, OffsetRollCornerType.All, .5, false, .005, false);
                    var mainGeoResult = SearchManager.GetResultGeometry();
                    foreach (var entity in mainGeoResult){
                        entity.Color = mainGeo;
                        entity.Level = mainGeo;
                        entity.Selected = true;
                        entity.Commit();
                    var thisChain10 = ChainManager.ChainAllSelected();
                    foreach (var draftChain10 in thisChain10) {
                        var draftSurface10 = SurfaceDraftInterop.CreateDrafts(draftChain10, roughSurfaceDraftParams, false, 1);
                        foreach (var surface10 in draftSurface10){
                            if (Geometry.RetrieveEntity(surface10) is DraftSurface roughDraftSurface10) {
                                roughDraftSurface10.Level = roughSurf;
                                roughDraftSurface10.Commit();
                    GraphicsManager.ClearColors(new GroupSelectionMask(true));
            offsetCutchain();
On 12/13/2022 at 10:39 AM, Roger Martin from CNC Software said:
Don’t know “why” at this point, but it makes a difference.
In -> offsetCutChain80()
Original:
int createdUpperLevel = 500;
int createdLowerLevel = 501;
Altered:
GraphicsManager.Repaint(false); // or remove this call
Result ->
Yes, you can share the ChainDataInterop project.
This has become a large issue for me. 😕
I've taken all the 'repaint(true)' out of the program that I can. Some of the areas require it to be there, or they do not work.
That being said, if I run two of my NetHooks, no matter the order, geometry gets moved 😕
I've tried added this code before and after each VOID but it's not helping.
            void deSelect()
                var selectedGeo = SearchManager.GetGeometry();
                foreach (var entity in selectedGeo)
                    entity.Retrieve();
                    entity.Selected = false;
                    entity.Commit();
https://github.com/UberGamz/RP-GEN-CREASES
https://github.com/UberGamz/RP-GEN-CUT
They work fine SOLO, but when ran together during one Mastercam session, they mix up geometry.
You could avoid this issue entirely by simply not using selection
                    foreach (var entity in creaseResultGeometryNew)
                        upperCreaseID.Add(entity.GetEntityID());
                        entity.Color = 10;
                        entity.Level = createdUpperCrease;
                        entity.Commit();
                    //Moves result geometry
instead of
                        entity.Color = 10;
                        entity.Commit();
                    GeometryManipulationManager.MoveSelectedGeometryToLevel(createdUpperCrease, true);
        var creaseResultGeometryNew = SearchManager.GetSelectedGeometry();
                            entity.Color = 11;
                            entity.Commit();
Here you are getting selected geometry, trying to select it again and calling commit()
That looks like a mistake, no need to select it again, you selected it already
                        entity.Color = 10;
                        entity.Commit();
instead of
                        entity.Color = 10;
                        entity.Commit();
I'm so glad when I write new code, I don't do this anymore 🤣
Works like a champ now.
                            entity.Color = 11;
                            entity.Commit();
How did you find that so fast?
