Haas Lathe.
I'm relatively new to this, but my post is just about exactly what I want. With one exception. I do NOT want to tool to nullify itself after a toolpath is finished. Does anyone know where this is in the post processor? The original file is the MPLFAN post.....
Yes.
The value gets assigned "zero" in 'ptoolend$'. The output then occurs in 'pl_retract' or 'pm_retract'.
ptoolend$        #Read from buffer 1 for prv_, current and next tool info
                 #end tool here, current and next valid
      if toolend_flag,
        sav_rev = rev #Axis Sub does not update to rev
        pcan
        if n1_gcode <> 1000,
          toolno = t$ * 100 + zero   #### < Value get assigned here.
          if millcc,
            pmillcca  #End mill conversion
          sav_gcode = gcode$
          gcode$ = zero
          pcool_off
          if posttype$ = two, pl_retract
          else, pm_retract
Then, is output here:
pl_retract      #Retract tool based on next tool gcode, lathe (see ptoolend)
      cc_pos$ = zero
      if home_type = one,
        pmap_home   #Get home position, xabs
        ps_inc_calc #Set inc.
        pbld, n$, psccomp, e$
        pcan1, pbld, n$, *sgcode, pfxout, pfyout, pfzout, *toolno, e$   ##### Either here, if home_type is 1
        pbld, n$, pnullstop, strcantext, e$
      else,
        #Retract to reference return
        pbld, n$, `sgcode, psccomp, e$
        if home_type = m_one, pbld, n$, *toolno, e$    #### < This is probably where the output occurs. This line is outputting a Tool Offset Cancel.
        pcan1, pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], "W0.",
        cutoff_proc = zero  #Reset flag if we are retracted
        if home_type > m_one, pbld, n$, *toolno, e$        ############ Or output here, if home_type is any another value.
This would fix it:
      cc_pos$ = zero
      if home_type = one,
      else,
        #if home_type = m_one, pbld, n$, *toolno, e$   ##### DEBUG < Commented Out toolno output!
You will also need to edit 'pm_retract':
pm_retract      #Retract tool based on next tool gcode, mill (see ptoolend)
      if home_type = one,
        if frc_cinit, cabs = zero
        pcan1, pbld, n$, *sgcode, pfxout, pfyout, pfzout, protretinc,
          *toolno, strcantext, e$
        pbld, n$, pnullstop, e$
      else,
        #if home_type = m_one, pbld, n$, *toolno, e$     ####### < Removed Tool Offset Cancel
          protretinc, pnullstop, strcantext, e$
Check and test the output.
Always, Always, make a couple backup copies of your Post, and save them in different folders to be sure you can always restore to a safe point.
The output is coming from a variable called 'toolno'.
The asterisk in front (*toolno) means the variable is "forced" to output.
