R value on Multi-Pases ROUGH and IJK on Multi-Passes FINISH?
Hello all,
   I am having World War 1 machines which are old and not enough memory to run simple stuff.  They have only 20KB, I have tried the R values in the program and they fit well.  However, I want on the last toolpath would be IJK so I can control the cuts better.  So I went to the "PARC" and monkey around with it. It only worked  for the R values but not the IJK on the last cuts.  Would you guys point me to the right direction?
Thank you,
   S.Luong
O1905(715-A27905-105-REVB OP3.NC)
(SOURCE = 715-A27905-105-REVB.MCAM)
(POSTED ON NOV.30.2023 AT 7*17AM)
(STEVEN LUONG, BY= CALMAX\STEVEN)
(MACHINE TYPE = VERTICAL, FANUC)
(CUSTOMER NAME = LAM RESEARCH)
(PART NAME = BLK, UPPER DISCONNECT, HTR 6)
(TOOLS LIST FOR OP3 = 1 TOOL)
(T2= .5, .500", 1/2" 3FLT CEM 1.25"LOC, CBD, * Z-.81)
(SETUP INFO, WOS = G56)
(X0 = RIGHT)
(Y0 = REAR)
(Z0 = TOP)
(CYCLE TIME = 45.75S)
N2(ROUGH AND FINISH LEFT OVER, CUT#31)
G0 G17 G40 G49 G80 G90
G53 Z0. M19
G53 Y0.
T2 M6(.5, .500", 1/2" 3FLT CEM 1.25"LOC, CBD,)
G90 G56 X-1.0552 Y.3154
S5000 M3
G43(D32)H2 Z2.
M8(DOC= Z-.81)
G1 F18.75
Z.1
G1 Z-.685 F30.
G41 D32 X-1.256 Y.0287 Z-.81
G3 X-1.265 Y0. R.05
G1 Y-.12
X-1.025
Y0.
G3 X-1.034 Y.0287 R.05
G1 G40 X-1.2348 Y.3154 Z-.685
G0 Z.5
X-1.2427
Z.1
G1 Z-.685
G41 D32 X-1.4435 Y.0287 Z-.81
G3 X-1.4525 Y0. R.05
G1 Y-.3075
X-.8375
Y0.
G3 X-.8465 Y.0287 R.05
G1 G40 X-1.0473 Y.3154 Z-.685
G0 Z.5
X-1.4302
Z.1
G1 Z-.685
G41 D32 X-1.631 Y.0287 Z-.81
G3 X-1.64 Y0. R.05
G1 Y-.495
X-.65
Y0.
G3 X-.659 Y.0287 R.05
G1 G40 X-.8598 Y.3154 Z-.685
G0 Z.5
X-1.4352
Z.1
G1 Z-.685
G41 D32 X-1.636 Y.0287 Z-.81 F15.
G3 X-1.645 Y0. R.05 ========================> I/J/K HERE
G1 Y-.5
X-.645
Y0.
G3 X-.654 Y.0287 R.05 ========================> I/J/K HERE
G1 G40 X-.8548 Y.3154 Z-.685
G0 Z.5
X-1.4352
Z.1
G1 Z-.685 F30.
G1 Y-.5
X-.645
Y0.
G0 Z2.
M9
G53 Z0. M5
G53 Y0.
G0 G90 G56 X0.
M1
T2 M6(.5, .500", 1/2" 3FLT CEM 1.25"LOC)
M30(CHARACTERS = 1,569 ~ 1.534KB)
#Region parc
parc            #Select the arc output
      if (plane$ = zero & (arctype$ = one | arctype$ = four)) |   #XY Plane
        (plane$ = one & (arctypeyz$ = one | arctypeyz$ = four)) | #YZ Plane
        (plane$ = two & (arctypexz$ = one | arctypexz$ = four)),  #XZ Plane
        result = newfs(two, iout)
        result = newfs(two, jout)
        result = newfs(two, kout)
      else,
        result = newfs(three, iout)
        result = newfs(three, jout)
        result = newfs(three, kout)
      if (plane$ = 0 & arctype$ < five) | (plane$ = 1 & arctypeyz$ < five) | # IJK is only for finishings and traditional toolpaths, highspeed would be R value
        (plane$ = 2 & arctypexz$ < five) | full_arc_flg$ | arc_pitch$ & (stock = 0 | stock1 = 0 | stock2 = 0) &
        not(iCommentCompare33 = iROUGH) & (iCommentCompare40 = iSemiFinish | iCommentCompare37 = iFINISH) &
        not(tool_op$ = 132 | tool_op$ = 134 | hst_flg) & (CircleMillFinishingIO = 1 | PocketFinishIO = 1 | PocketFinishIO = 1),
        #Arc output for IJK
        # If you do NOT want to force out the I,J,K values,
        # remove the "*" asterisks on the *i, *j, *k 's below...
        if plane$ = zero, *iout, *jout, kout #XY plane code - G17
        if plane$ = one, iout, *jout, *kout  #YZ plane code - G19
        if plane$ = two, *iout, *jout, *kout  #XZ plane code - G18
        !i$, !j$, !k$
        #if not(xform_type = 13 | xform_type = 16 | xform_type = 18) & OldMR1 = 5 & (plane$ = two), [if mprint(sG18IO), exitpost$] #
        #if not(xform_type = 13 | xform_type = 16 | xform_type = 18) & OldMR1 = 5 & (plane$ = one), [if mprint(sG19IO), exitpost$] #
      else,
        #Arc output for R
        if abs(sweep$)<=180 | (plane$ = 0 & arctype$ = five) | (plane$ = 1 & arctypeyz$ = five) |
          (plane$ = 2 & arctypexz$ = five), result = nwadrs(srad, arcrad$)
        else, result = nwadrs(srminus, arcrad$)
        *arcrad$
      if ProgramQCIO = 1 & not(gcode$ = 3) & FilteringOverRideArcFeedRateIO = 1 &
       not(sContourType = 1) & (i$ = 0 & j$ = 0) & not(icommentCompare45 = iEngravings) &
       not(tool_op$ = 14) & not(iCommentCompare239 = iGnoreCheck) & not(tool_typ$ = 24) &
       not(tool_op$ = 102) & not(tool_op$ = 3) & not(tool_op$ = 132) &
       not(iCommentCompare2441 = iHole) & not(tool_op$ = 43),
       [if mprint(sFilteringOverRideArcFeedRateIOOff), exitpost$]
#EndRegion parc
