Electrode surface finish question
Trapper Paul
Greetings forum
I'll try not to yell, as a post question or get in trouble. Believe me all forums have troubles.
Anyways,
What is everyones opinion about surface finish on an electode made with mastercam in a cnc mill?
What produces a better trode finish? Having the (tool) "total Tolerance" turned on or turned off? The size of the program doesn't matter in this application. Thanks in advance. cheers.gif
Paul
Most common good strategies for finish :
Surface ->contour + surface->shallow
Surface->scallop
Surface->project->blend
Surface->flowline
I prefer the first
You can not turn off total tolerance ,you can turn off filtering
I use filtering on every toolpath 2:1 ith total tolerance 0.005 mm
Depends on the machine .
Filter turns your little line segments to arcs and lines of bigger size .
You pay with accuracy of the toolpath according to tolerance
So ,if your machine has little memory buffer ,DNC feedback ,bad table backlash and so on filtering helps ,if the nmachine is new wth dataserver and all the gadgets you can turn it off
Yes !
As I saw in olD OKUMA ONCE WITH CIMATRON NON-FILTERED PAth (THey simply don`t have this feature ) the feed can suddenly drop down 10-20 and more times .
On machines with backlash you can expect shudder from acceleration-deceleration .
DNC drip feeding a lot of little blocks also can be aa problem ,the controller will stand waiting for a new bunch and tool milling stand still.
And a problem of machines with small bubble memory ,like an old relict I run now from time to time with 40Kb of it .
What is 40kb of surface-contour of a modest accuracy and common complexity for unfiltered toolpath
Filtering shortens my programs 5-10 times !
Filtering is a good tool ,but first of all to get good electrode finish you must use good cutting strategy .
