need help about post
Tom
I'm looking for the way to force X and Y out
before entering subprograms in translate retangcular toolpath.
for instance, after a toolpath translated several times along x axis
the output looks like this
X-3.75Y0
M98P0001
X-2.75
M98P0001
X-1.75
M98P0001
And this is the output I'm looking for
X-3.75Y0
M98P0001
X-2.75Y0
M98P0001
X-1.75Y0
M98P0001
I have tried to replace postblocks: pxout,pyout under prapidout
by pfxout and pfyout. The result looked
good at the above section in my program. but confused at non-subprogram sections: It also forced X & Y out where it not supposed to do. So..I changed it back tongue.gif whew....
I'm using MCam V8.1.1 with MPFan
[ 09-19-2001: Message edited by: TOM ]
You can't force a post block with an asterisk (e.g. *pxout). If present in your post, pfxout calls a post block that forces xabs (e.g. *xabs).
It's easier in this case to find the end of each sub, rather than to trap the rapid move between subs, recognizing them as being different than a regular rapid move.
Here we can update the previous values of xabs and yabs at the end of each sub call to force the output of these modal variables on the next positioning move.
In psub_end_m and psub_end_s add these two lines:
prv_xabs = c9k
prv_yabs = c9k
e.g.
psub_end_m #End in main level
n, "M99", e
prv_absinc = -1
prv_xabs = c9k
prv_yabs = c9k
The server clock looks like it was messed up today. We did suffer a power outage today. Back to normal now.
[ 09-19-2001: Message edited by: Dave Thomson ]
Access the Mp.hlp file (I believ it is included in a standard installation), and find the 'MP Processing of Subprograms' entry. I believe that will answar your questions.
As I understand it, you wish output of both X and Y coordinates (and possibly also Z), immediately before starting a subprogram. I belive the best way to do this is to check for changes in the sub_level variable in the prapid and pzrapid postblocks, and force the X and Y coordinates, if sub_level has changed The code would be something like this:
if prv_sub_level <> sub_level, n, sgcode, *x, *y, e
else, n, sgcode, x, y, e
I hope I have been of help.
I feel much better now.
Dave' 2 magic post lines did the trick!perfectly!
Many thanks to you guys. for all your input
and special thanks to this forum. where I
( while my dealer' leaving everything on my own wink.gif )
I have been thinking a little more about the problem. Dave's suggestion will force X and Y, whenever the subprogram level goes up towards the main program level, while my suggestion will force X and Y whenever the subprogram level changes. Dave's suggestion may be sufficient, but I am not certain it will give the correct code, if you have a non-transform subprogram at a lower level than a transform subprogram. My suggestion should create correct code in all instances, but may produce unneeded code in some cases. If you have enough memory in the control, I believe my suggestion would be your best choice.
