Custom drill cycles for probing.
Bruce Caulley
Ahoy!
I have been asked to investigate the use of the probes in our 5 axis deckels for more of our general inspection work. I have a manual for the touch probe cycles for a Heidenhain TNC430 control, but just need an example of how I would add these into a post. Will I need to use miscelaneous integers or custom parameters for the field definitions or can it be done so that instead of having:
depth
peck
dwell
etc
etc
under the drill parameters page it has:
1st point xaxis
1st point y axis
nominal diameter
etc
etc
Any help appreciated.
Bruce
Here's what I have added into an MpMaster post
uptol = mr1$ #UPPER TOLERANCE LIMIT #### MISC REALS mr1 and mr2 ARE USED
lowtol = mr2$ #LOWER TOLERANCE LIMIT #### TO SET THE UPPER AND LOWER TOLERANCES
z_height = mr10$ #RAPID HEIGHT
#### IN ALL CUSTOM PROBE CYCLES
fmt A 2 drl_prm1$
fmt B 2 drl_prm2$
fmt I 2 drl_prm3$
fmt J 2 drl_prm4$
fmt K 2 drl_prm5$
fmt S 2 drl_prm6$
fmt W 2 drl_prm7$
fmt X 2 drl_prm8$
fmt Y 2 drl_prm9$
fmt Z 2 drl_prm10$
fmt C 2 z_height
fmt T 2 uptol
fmt U 2 lowtol
Here are my macro calls
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
#if drillcyc = 8, pcan1, pbld, n, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout,
# prdrlout, dwell, *feed, strcantext, e
if drillcyc$ = 8,
sub_prg_call = peck1$
pcan1, pbld, n$, *sg00, *sgabsinc, pfxout, pfyout, strcantext, e$
pbld, n$, "M98", *sub_prg_call, e$
#else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 9,
"(PROBE ID)", e$
"(AUTO CENTERING CYCLE)", e$
pbld, n$, "G65 P8010", *z_height, "D0.", *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm10$, e$
pbld, "G04 P100", e$
#pbld, "M98 P8098", e
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 10,
"(PROBE OD/BOSS)", e$
pbld, n$, "G65 P8017", drl_prm1$, *z_height, "D0.", *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm10$, e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 11,
"(FIND X CENTER INSIDE)", e$
pbld, n$, "G65 P8006", *z_height, "D0.", *drl_prm3$, *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm10$, e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 12,
"(FIND Y CENTER INSIDE)", e$
pbld, n$, "G65 P8007", *z_height, "D0.", *drl_prm4$, *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm10$, e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 13,
"(FIND Y STRAIGHTNESS)", e$
"(AUTO ROTATION CYCLE)", e$
pbld, n$, "G65 P8015", *z_height, "D0.", *drl_prm4$, *uptol, *lowtol, *drl_prm8$, *drl_prm9$, *drl_prm10$, e$
pbld, "G68","R",no_spc$, 35, no_spc$,"107", e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 14,
"(FIND X CENTER OUTSIDE)", e$
"(ON THE X AXIS)", e$
pbld, n$, "G65 P8006",*drl_prm1$, *drl_prm2$, *z_height, "D0.", *drl_prm3$, *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm8$, *drl_prm10$, e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 15, [
"(FIND Y CENTER OUTSIDE)", e$
"(ON THE Y AXIS)", e$
pbld, n$, "G65 P8005",*drl_prm1$, *drl_prm2$, *z_height, "D0.", *drl_prm4$, *drl_prm6$, *uptol, *lowtol, "V0.", *drl_prm7$, *drl_prm9$, *drl_prm10$, e$
pcom_movea
pdrlcommonb
#~drillcyc, e
if drillcyc$ = 16,
"(FIND A CORNER)", e$
"(AUTO EDGEFIND CYCLE)", e$
"(ON THE XY AXIS)", e$
pbld, n$, "G65 P8013",*drl_prm1$, *drl_prm2$, *z_height, "V0.", *drl_prm7$, *drl_prm8$, *drl_prm9$, *drl_prm10$, e$
pcom_movea
I am getting ready to add inspection routines over the next couple of months using our existing macros some I am developing and dprint.
