NetHasp License Problems
ILv2Rk
We have a NetHasp License and have had nothing but problems with the client machine being disconnected from the server. this happens 5-10 times per day. We have tried everything that our reseller has said but had no luck. Just wondering if anyone else has had this problem and overcame it. headscratch.gif
Jeff
Is that computer used for anything else? What I'm really getting at is the 10-incoming-connection limit that Windows XP Pro has (it's 5 connections for XP Home).
So for example, the NetHASP server is an XP Home computer. Let's say four people check out Mastercam licenses. And then somebody else, not using Mastercam, accesses files in a shared folder on that NetHASP server computer, 5 connections are used up. Now when a fifth person tries to check out a Mastercam license, they can't. Although you still have a remaining Mastercam license, you've maxed out your connections to that XP Home box.
To explain further,
We can have MC open and running on the client machine and then a message will pop up saying "Sim has become disconnected and Mastercam will now close. You will get one chance to save your work. sorry for this inconvienience."
When this happens there is no apparent reason. The Server machine did not reboot or shut down.
We have tried giving the server a static IP address and then editing the .ini file to aim at that address and also changing the timeout to "0". still no luck
Does your nethasp.ini look something like this?
[NH_COMMON]
NH_TCPIP = Enabled
[NH_TCPIP]
NH_SERVER_ADDR = 192.168.1.20 ; or whatever your server's IP is
NH_PORT_NUMBER = 475
NH_TCPIP_METHOD = TCP
NH_USE_BROADCAST = Disabled
I'd avoid setting NH_SESSION and NH_SEND_RCV for the time being.
When this happens, are you able to ping the NetHASP server from the client computer while that dialog is displayed?
I don't know if you can ping the server while the message is displayed, i will have to try it.
What are you thinking that will tell us?
Just want to be certain that the connection between the client and the server, regardless of the socket needed to keep the NetHASP connection alive, exists. Yes, you can ping. The "Sim has become disconnected" dialog is modal, so at that point before you click "OK" to dismiss the dialog, you should be able to fire up a command prompt on the client computer so you can try to ping the server.
