High Speed Horizontal No Fillet
Wet-Tech
I just tried it in here. It worked the way it should in both X & V9 with both standard pocket & 2d contour toolpaths having a .25 radius and using a 5mm ball mill. The cutter rolled around corners like it should have. Is your toolpath associated with the geometry?
That is what Horizontal Area is for. But if your trying to keep from banging into vertical corners smoothing will help. If your talking about banging into floor fillets, you can add a different stock amount to the wall than your using on the floor. that might help.
Yes, that is a good suggestion. But in this case there is a tangent radius so the side wall isn't the problem finish is my primary concern. The part is the cavity area of a mold. It is also hardened so any little whip of the cutter tends to leave a visual mark though it is usually not measurable. I'm just trying to save myself any bench time if I can.
