Poor verification from solids toolpath
RMagnusson
I've tried running some toolpaths on my newly created solid part model, but only with limited success.
The part looks like a long double-d shaped pan (rectangle but with the short Y-axis ends rounded) with several bosses sticking up from the base.
After reading Go Navy's post 'tool paths on solids' I used the method: create curves on all edges- toolpaths-contour- and selected the inner vertical face of the pan by chaining its lower-most geometry.
The toolpath looks perfect. It even follows the tight S shaped contours at either end.
When I verify the long straight walls come out clean, but any curved contour only gets cut every 20 degrees for about 5 degrees. Like the cutter is skipping when cutting the inside radii of the pan wall contours.
I am using a .250 flat endmill and the smallest thing that need be cut is a .5 DIA arc that travels 180 deg.
Is this when I need to use an stl to verify? Am I chaining my geometry incorrectly? Should I not use the create curve function?
Its probably something mind numbingly simple that will (hopefully) come to me when I wake up in the morning....but if not, confused.gif
Thanks for reading folks.
