Check Surface in Surface Rough Pocket
John Giess
No John, in surface rough pocket there is no option for check sufaces. If you really need to use them you'll need to use a different path.
Surface rough pocket is just that, a roughing routine, it does not assume there will be anything to stay away from. You could use a solid boundary to keep it away from something but not a check surface
If you are not using a boundary around the outside of your part you could create a boundary and on the parameters page click the tool containment to outside, it should remain outside of your boundary.
A better option, I think, is to model a feature around where you want to avoid and just add that as past of the cutting surfaces. I usually do this and move it to a different level. Then when I don't need to use it to stay away I just turn the level off. The rough paths still use it but for finishing you can work with the entire model
[ 03-31-2006, 06:09 PM: Message edited by: John Paris @ Kevlin Microwave ]
