Error when changing config file.
rdshear
I am running X MR2 and have run into a problem. I have my own config file as there are two people on the computer I use (at different times of course wink.gif ) I decided to check the colors and cancelled out of the menu (red X at bottom). Upon doing this, I got the error:
"Failed to load resources from resource file, Please check your setup."
When I clicked OK, Mastercam closed.
I re-booted and re-loaded Mastercam only to find that any time I used the config, it would reply with the same message.
The only way around it was to re-load the default config file, save it as mine, and then make my changes.
I thought the problem was because I closed the config dialog box with the red X (Cancel) button instead of the green check (OK) button, however, I have had this problem three times now in two days as I try to get the config where I want it using the green check. I am usually changing shading or color settings when it happens.
It seems the file is getting corrupted or it's not re-loading properly or something. I know I changed these settings several times in MR1 and never saw this error. Anyone have any ideas other than "don't play with the config file"? confused.gif
Rick
