Mori Seiki Post
MasterCAM Rulez
Can someone show me how to put "PERIOD" in the digits. cause the mori seiki doesnt have a period like any other post. it very hard read program without the period. Look at the below this what I mean
Mori Seiki Post : MPLTL3YC
Z2000
MPLFAN Post
Z.2
I want to put the period like MPLFAN post.
Thank in advance
Hey bud!
Technically speaking it is a decimap point you want not a period but that is beside the point.
You'll need to look in the post and look for this;
fmt N 4 n #Sequence number
fmt X 2 xabs #X position output
fmt Z 2 zabs #Z position output
fmt U 3 xinc #X position output
fmt V 3 yinc #Y position output
fmt W 3 zinc #Z position output
fmt 11 cabs #C axis position
fmt 14 cinc #C axis position
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt R 2 arcrad #Arc Radius
fmt F 12 feed #Feedrate
fmt P 11 dwell #Dwell
fmt C 2 crad #C axis start radius
switch them to this;
fmt C 11 cabs #C axis position
fmt H 14 cinc #C axis position
fmt B 4 indx_out #Index position
fmt F 18 feed #Feedrate
fmt M 5 cantext #Default cantext
fmt C 2 crad #C axis start radius, G107
fmt H 2 tlrad #C axis cancel, G112, currently using C position
fmt is the nway the number is represented.
Hope that helps
I think the previous method will not work in your case. Most likely you will get an error indx_out not defined or whatever. You want to search in the post for the format statments FS. The xabs for instance uses format statment 2 look for FS 2 change the coresponding FS to reflect the desired output.
fs 2 0.4 would give you the Decimal note the decimal in the format statment
Allan
