4th axis NOT on X or Y or Z
tala
Hi all,
So... I've got a rotary table mounted at an
angle to the Z axis such that I can machine
12 flats which are at an angle to the
centerline of the rotary table's axis.
The angle is: 26.565 degrees. (nice round number)
I'm thinking I've done this in MCam in the past.
However, I may be wrong or simply thinking of
parts I've programmed in other systems. (don't
ask... please)
I only need to position the 4th axis and then
machine the flats 2D...
Is there a way to obtain 4th axis output with
the axis of rotation NOT on one of the major
three axes?
Thanks, Tala
[email protected]
If you machine the part 5-axis for a rotary table that tilts about B (Y), then throw away the B axis, you're all set. The tilt-rotary posts, however, assume the part axis is on Z axis. E-mail me if you have trouble with this. You can 'legally' throw away the B axis in this case, because the part is already tilted at that angle.
Thank you John,
Thanks very much for the suggestion.
After Marc and I looked at your
response here and using
a 5axis MPMaster Post the rest
was pretty easy to figure out.
Your suggestion pointed us in the right direction.
I rotated the part so the axis of the
rotary table was normal to the top plane.
Using the plane of the cut for a 2axis
operation and posting to a Haas generic
5axis MPMaster Post I obtained NC code with
rotation for A axis and B axis. Per your
suggestion I'm editing the NC code to strip
the A axis code and I'm good to go.
(Powergrep is a nice simple way to strip
the A axis code quickly.)
Again, Thanks very much...
Tala
[email protected]
