MPMASTER post out H1 workoffset
cappy
Hello,
I have begun the long road to tweaking my post.
I am using MPMASTER.pst with a Milacron 950 Aramatic Control on 630 Maxim. I understand the tool plane check box with work offset set 0-g54 1 g55 etc. How do I get it to H1 format. I have seen something in the post called:
pwcs #G54+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level$ > zero, force_wcs = zero
if sav_mi9 = 1, workofs$ = sav_workofs
if workofs$ < 0, workofs$ = 0
if workofs$ <> prv_workofs$ | (force_wcs & toolchng) | sof,
if workofs$ < 6,
g_wcs = workofs$ + 54
*g_wcs
else,
p_wcs = workofs$ - five
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs$
I have seen other posts with H values.
Please help.
thanks,
Greg.
John,
The H1 is a work offset. We have 16 per pallet.
I know H's can also be used for a tool length offset as in a Fanuc 18M series.
Basically we mill on B0, B90, B180, B270.
The work offsets are H1-B90, H2-B270, H3-B0, AND H4-B180. I don't think we have used anymore than four.
Greg.
Terry,
The MAXIM has a AWC automatic work changer. ^ pallets shuttle. I am not sure what you mean by pallet index. We do not index or shuttle a new pallet in the machine during a part program. Once the "1st operation" is done. The pallet is sent out and the "2nd pallet operation" is performed. Regardless of what pallet is in the machine the B - side face will have it's own workoffset H value as mentioned above. If I work on B90 the work offset coded is H1.
John,
The sample below is what our old APT was doing.
Notice the H1 value in the long line of code.
N1(PGM,=" A24431B MAX C/N -NONE- HOUSING "L-1 D20/FEB/ 7 14:10
:G70 G129 P6 C6
N5G1F0.1M5
N10G0B180.F100.S20
:15G0G70F100.T10300000M6
N20 (MSG, 3.0 MILL
:25G80G70X-10.125Y17.135Z0.B180.R5.105F100.S500T38162500H1M3M8
N30G1X-10.125Y17.135Z4.605B180.F100.S500H1M3M8
N35Y11.06F8.
N40X-8.025
N45Y16.46
N50G0Z5.105
:55G80G70X-10.125Y17.135Z0.B180.R4.86F8.S500H1M3M8
N60G1X-10.125Y17.135Z4.36B180.F100.S500H1M3M8
N65Y11.06F8.
N70X-8.025
N75Y16.46
N80G0Z4.86
:85G80G70X-10.125Y17.135Z0.B180.R4.615F8.S500H1M3M8
N90G1X-10.125Y17.135Z4.115B180.F100.S500H1M3M8
N95Y11.06F8.
N100X-8.025
N105Y16.46
N110G0Z4.615
:115G80G70X-10.125Y17.135Z0.B180.R4.605F8.S500H1M3M8
N120G1X-10.125Y17.135Z4.105B180.F100.S500H1M3M8
N125Y11.06F8.
N130X-8.025
N135Y16.46
N140G0Z4.605
N145G1M26
Couple of ways to do this...
g_wcs = workofs$ (or + 1 if you want a work offset of 0 to equal H1)
*g_wcs
!workofs$
At the top of the file change this:
fmt G 4 g_wcs #WCS G address
to this:
fmt H 4 g_wcs #WCS G address
With this you still need to select your work offset in mastercam as you were before, it's not tied to the angles.
