Arc settings
bogusmill
In control def. on the arc page we have arc breaks at quadrants in all 3 planes. Is this how most of you set this up?
I know we used it because of problems our Bridgeport had using other settings and we just continued doing it out of habit. Any advantages to any of the other settings?
I don't break arcs at all and I create them in all planes. Then again I'm programming for brand new Fanuc Controlled machines which makes things simple. biggrin.gif
Good day,
OG
I am having trouble with a new Fanuc 0ie control
on a vert. mill with NC code data of arcs with:
G3 X2.3465 Y2.3124 Ixxx jxxx
X2.3466 Yxxx Ixxx Jxxx
Note :
the X or Y value only changes .0001 or .0002
and the machine generates a full circle which
violates then part geometry. does not show in backplot or Cimco backplot.
I had to switch to "R" NC data
This happened about 5 times in 4 programs
anyone have this happen?
Tony G
CNCme Engineering
X Beta Site
SO Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
Good day,
That Break arcs applies on full arcs. The system can generate arcs smaller than 90 deg even with
breaks on.
Tony G
CNCme Engineering
X Beta Site
Good Day,
This is actual code that generated a full arc
on the machine
G2 X5.7756 Y-4.1933 I-.229 J-.1608
X5.7757 Y-4.1941 I-.2798 J0.
Tony G
CNCme Engineering
X Beta Site
Good Day,
Longer ver. with G1 at both ends.
code shown at >
G1 X5.7815 Y-4.1801
G3 X5.7746 Y-4.2037 I.0372 J-.0236
X5.7753 Y-4.2113 I.0441 J0.
X5.7732 Y-4.2396 I.7054 J-.0645
X5.7892 Y-4.2529 I.0258 J.0148
X5.9656 Y-4.3258 I.1764 J.177
X6.2155 Y-4.0759 I0. J.2499
X6.1468 Y-3.9039 I-.2499 J0.
X5.9656 Y-3.8263 I-.1812 J-.1726
X5.7248 Y-4.0081 I0. J-.2502
X5.7181 Y-4.0203 I.0077 J-.0122
X5.7248 Y-4.0325 I.0144 J0.
G3 X5.8506 Y-4.2688 Z-.5107 I.0749 J.0002
G1 X5.8509
This toolpath is surface high speed horizontal
Tony G
CNCme Engineering
X Beta Site
