Toolpath finishing problem
Bruce
Hi all,
MC 8.1 mill.
I have a Surface toolpath-finishing problem. The pocket has vertical sides, the base is V shaped and all corners have been blended/filleted
· I have created the pocket using ruled surfaces for the vertical sides
· Flat boundary surfaces for the base
· Fillets/blends for all corners
When I rough the pocket with the "rough pocket toolpath" no problem, but when I try to finish the pocket with any of the surface finishing toolpaths I encounter problems.
When the toolpath get to the corner areas of the pockets it machines the inside but also the outside surface. This is not constant at each corner and tends to be only a few tool path lines.
Any suggestions on what is causing this.
PS- Can you attach a picture file to a topic as a picture can make to problem much clearer.
Bruce, I find this to be a common problem with vertical surfaces. Apparently they are not 'perfectly' vertical. I almost always do a backplot to see where the tool cuts on the wrong side, then 'Create-Line-Multi' (F8) and draw a tool containment boundry thru the bad places. Go to parameters, check the tool boundry box, and regen. Always works. smile.gif
BerTau
