What is TP.CFG?
Lucky
I am running V9 SP1
I installed V9SP1.EXE and everything seems to be O.K. My APPS directory contains appmch9.dll dated 3/6/2002 and ctour9.dll dated 2/22/2002 from an earlier patch - is this O.K.?
Can anyone explain the file tp.cfg dated 3/25/2002 in my APPS directory? Is this file created/edited using appcfg.dll C-Hook?
What does the file tp.cfg locateed in the APPS directory do? Mine looks like this:
[appmch]
Note: these configuration settings are described below.
Key: (future use) this question is reserved for a future release
(under development) new control is available but the
processing code is not available.
(y/n) new control and processing is available, 'y' to enable
and 'n' to disable.
1. Enable new features added after v9.0 is released (future use)? n
2. Enable new v9.0 parallel controls (future use)? n
3. Enable new v9.0 radial controls (future use)? n
4. Enable new v9.0 project controls (y/n)? n
5. Enable new v9.0 flowline controls (future use)? n
6. Enable new v9.0 contour controls (y/n)? n
7. Enable new v9.0 pocket controls (y/n)? n
8. Enable new v9.0 plunge controls (future use)? n
9. Enable new v9.0 steep controls (future use)? n
10. Enable new v9.0 shallow controls (y/n) ? n
11. Enable new v9.0 pencil controls (future use)? n
12. Enable new v9.0 leftover controls (under development)? n
13. Enable new v9.0 scallop controls (y/n)? n
14. Enable new v9.0 pocket dialog (future use) ? n
15. Enable new v9.0 contour dialog (future use) ? n
16. Enable new v9.0 parallel dialog (future use) ? n
17. Enable new v9.0 gap controls (y/n)? n
18. Enable new v9.0 cut depths controls (y/n)? n
19. Enable new v9.0 collapse controls (y/n)? y
20. Enable new v9.0 edge controls (y/n)? n
21. Disable single surface sharp corner test (y/n)? n
22. Disable appmchX.dll (y/n)? n
23. Use old version 8 flow5ax (y/n)? n
24. Use old version 8 rotary4ax (y/n)? y
25. Selection mode for rotary4ax (0/1/2)? 0
26. Selection mode for flow5ax (0/1/2)? 0
(end of file)
Sorry I was not clear.
I would like to know what this file does. How is the configuration of Mastercam affected by these settings? Can certain functionality be enabled / disabled by editing this file?
Thanks for the reply.
