Lathe stock advance issues
Travis B
I have edited the mplmaster post to out put the correct code for lathe stock advance. The problem I am having is where it outputs the code. For this example the lathe stock advance is the first tool path operation. If I do not select USE TOOL STOP, it outputs the code before pheader$. If I do select USE TOOL STOP, it outputs the code between lsof$ and ltlchg0$ of the next tool path operation. Is there a way to specify where to output this code? This seems to only be an issue when it is the first tool path.
