How to force code?
Bugzpulverizer
I am programming for two old G & L machines, one is a 25VS VMC, and the other is a 18U lathe. They need all codes on every arc line. It will not default x, y, i, j, or k, in arc movements. Is there a way to change the generic Mastercam post to force it to post those codes when executed? It's really a pain when doing roughing cycles on the lathe when fillet radii are involved. Thanks in advance.
fmt  X  2   xabs        #X position output
fmt Z 2 zabs #Z position output
XYZ's use a format type to control their output. In this case they are using format type 2.
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
Format type 2 would be a 4 place (inch) decimal number.
If you added a character to the format 2 type you can make it non-modal.
Set the format to look like this:
fs2 2 0.4 0.3n #Decimal, absolute, 4/3 place
The 'n' will make all variables that use format type 2 to non-modal.
a quick, dirty way to force the G-codes out is to use the post variable force out symbol. In your rapid, line and arc output sections force the sgcode variable. Example with the line output section:
plinout         #Output to NC of linear movement - feed
pcan1, pbld, n$, sgfeed, sgplane, *sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, feed, strcantext, scoolant, e$
The * on the sgcode variable will force it out every time.
That worked great also. thank you much!! I've got one more. In the beginning of my programs I want it to give a tool list. I've got my post to list the tool numbers in the order they are called, but I can't get it to put the comment for the tool next to ( T01= ???). I want it to appear where I put the question marks. Here's what I get:
(A6503 )
(P/N:)
(BOGLINO - DATE:)
( T11= )
( T12= )
( T09= )
( T01= )
I think I have tried nearly every manipulation in my small aresenal of knowledge of editing .pst files. Here's hoping you are three for three today.
