file converter
tgriffin61
I dug up a list that Esprit suports, try only the common converters to translate.
Data Exchange
ESPRIT reads data from the following native
formats: ACIS® (SAT), AutoCAD (DWG), CSV,
DXF™, Autodesk Inventor®, IGES, Mechanical
Desktop®, Parasolid® (X_B, X_T), Solid Edge®,
SolidWorks®, TXT, VDA-FS. Optional data readers
are available for: CATIA®, Pro/ENGINEER®,
Unigraphics®, STEP, STL.
Local
Can you export the Esprit drawing into another format that Mastercam can be read ?
It depends on what is in your drawing as to the method you should use. Check your help pages as to what the limitations that each converter has before we really confuse you here.
eg STEP, STL, X_T, Iges are good for things that have volume ( solids, surfaces, etc)
where DXF, DWG are good for 2D, 3D wire-frames and such.
