Custom drill cycle for G10's
Jrygus
I am trying to modify Mpmasters custom drill cycles to create my G10 lines. I have most of it worked out except for my X,Y,Z, values. This is what i have so far
Two Variable defined
fmt L 1 lvalue #L value for G10 2 or 20, 2 for 54-59 and 20 for g54.1 p
fmt P 1 pvalue #P value for G10, 1-5 for G54-G59, and 1-> for g54. p
And my drill cycle looks like this
if drillcyc$ = 14,
lvalue = peck2$
pvalue = peck1$
"G0 G90 G10", *lvalue,*pvalue,*pfxout,*pfyout,*pfzout e$
What i need is the value of the pfxout, pfyout and pfzout to be the negative value of what they come out as. I have been trying to multiply them by -1 to change the sign, but i cannot seem to affect them, or set thier value to another variable. If anyone can help i would appreciate it.
I do it this way and I think it's a little more straightforward to handle;
# THIS IN IN THE TOP OF THE POST NOTES SO WE KNOW WHAT'S UP WITH THE MISC. REALS...
# mr1 - G10 Work Offset X Value
# mr2 - G10 Work Offset Y Value
# mr3 - G10 Work Offset Z Value
# mr4 - G10 Work Offset B Value
#THIS SECTION GETS ADDED NEAR THE AXIS FORMATS SECTION TO KEEP THINGS CLEAN...
# ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ
# Axis output formats - For G54.1 Px in Misc. Reals and shifts, etc...
fmt X 1 mr1 # X Axis Pos
fmt Y 1 mr2 # Y Axis Pos
fmt Z 1 mr3 # Z Axis Pos
fmt B 1 mr4 # B-axis rotation in degrees
#THIS SECTION GETS ADDED IN YOUR PHEADER SECTION WHEREVER YOU SEE FIT - USUALLY BEFORE PROGNO CALL
pheader # File header
!mr1
!mr2
!mr3
!mr4
"%", e$
#ADD THIS AFTER PROGRAM INFO
"(******************************)" e$
"G90 G10", pwcsp, *mr1, *mr2, *mr3, *mr4, e$
"(X ZERO IS )" e$
"(Y ZERO IS )" e$
"(Z ZERO IS )" e$
"(B ZERO IS )" e$
" " e$
#ADD THIS POSTBLOCK SECTION SOMEWHERE IT MAKES SENSE THOUGH NOT INSIDE ANOTHER POSTBLOCK
pwcsp #Out put "P" for G10 Line
if workofs < 6,
p_wcs = workofs + 1
"L2", *p_wcs
else,
p_wcs = workofs - five
"L20", *p_wcs
Then in your first operation in your part, you set up the values you want in there and you're off to the races.
O1361 (210-1361-001 FIXTURE )
(PROGRAM-VERSION=1)
(PROGRAMMER=JOE788
:D
(RUN-TIME=00-00-00)
(CUTTING-TIME=00-00-00)
(AUX-TIME=00-00-04)
(SECURITY-CLASS=1)
(PROGRAM-TYPE=0)
(PROGRAM-CLASS=0)
(COMPANY - ACME WIDGETS)
(PRINT - 210-1361-001 FIXTURE )
(PROGRAM - O1361 )
(POST - *********.PST )
( G54.1 P2 )
G90 G10 L20 P2 X-15.9453 Y0. Z-13.4107 B135.
(X ZERO IS )
(Y ZERO IS )
(Z ZERO IS )
(B ZERO IS )
Like this ^^^
Use this;
fmt  P  4   p_wcs       #WCS P address
if drillcyc$ = 14,
"G0 G90 G10", pwcsp, *pfxout,*pfyout,*pfzout e$
pwcs #G54+ coordinate setting at toolchange
if workofs < 6,
g_wcs = workofs + 54
*g_wcs
else,
"G54.1", *p_wcs
if workofs < 6,
p_wcs = workofs + 1
"L2", *p_wcs
else,
"L20", *p_wcs
Thanks Apps Guy for the help. What i ended up doing was a combination of things. I stole some of your logic to set the L and the P, and then i am using the Drill variables to get my X Y Z. So now my process will be, Create a point that represents the center of rotaion/common on machine. Then in my drill variables i right click and choose X/Y/Z coordinate for each drill variable and select the center of my rotation.
This is how my Post ended up
fmt L 4 lvalue #L value for G10 2 or 20, 2 for 54-59 and 20 for g54.1 p
fmt P 4 pvalue #p value for G10 1-5 for G54-G59, and 1-> for g54. p
fmt X 2 wsetxval #X value of center of rotation
fmt Y 2 wsetyval #Y value of center of rotation
fmt Z 2 wsetzval #Z value of center of rotation
if drillcyc$ = 14,
if workofs$ < 6,
lvalue = 2
pvalue = workofs$ + 1
else,
lvalue = 20
pvalue = workofs$ - 5
wsetxval = peckclr$ * -1.
wsetyval = retr$ * -1.
wsetzval = dwell$ * -1.
"G0 G90 G10", *lvalue,*pvalue,*wsetxval,*wsetyval,*wsetzval, e$
This is how the cycle looks in MC
For now, the output has to be edited down to just the G10 lines, but it eliminates the creation of them manually. Thanks again for the help.
