Wear not always working
due
here's my problem. I get wear to work in the contour toolpath and that is it. If say I do a pocket and on the rough/finish tab I set it to wear I does not compensate for the undersize cutter I use. I am posting to a dynapath controller and trying to read the code is another topic ( I have not found a code cheat sheet for reading it). Could the post not be set up correctly? I do not edit these, I know my limits.
If what you're looking for is comp in roughing it doesn't exist; roughing executes without diameter comp active ( using programmed nominal tool dia) diameter comp is only activated on finish for the walls/islands...
so if you program for a 1/2" tool then use a .390 regrind the amount left on the walls for finish is your finish step plus the difference of nominal to actual cutter radius
"basically wear and computer do output the same code, wear simply add a G41 or a G42 to the first move"
On a dynapath controller there is no G's.It is blended with symbols that I do not know how to translate.
From what I can tell it is turned on in the post.
In the control definitions under cutter comp it has check marks by " contoller supports wear". Here is a sample of code for a pocket with wear on but does not work at the machine.
(POCKETTE)$
N1(9)M6T1$
(T)TOOL - 1 DIA. - .375$
N2(9)M03S1426$
N3(0)X1.0215Y1.1076$
N4(0)Z0.25$
N5(0)Z0.1$
N6(1)Z-0.25F6.3$
N7(1)Y0.9276$
N8(1)X2.0015$
N9(1)Y1.1076$
N10(1)X1.0215$
N11(1)X0.7403Y1.3888$
N12(1)Y0.6463$
N13(1)X2.2828$
N14(1)Y1.3888$
N15(1)X0.7403$
N16(1)X0.459Y1.6701$
N17(1)Y0.3651$
N18(1)X2.564$
N19(1)Y1.6701$
N20(1)X0.459$
N21(1)Z-0.15$
N22(0)Z0.25$
N23(0)X0.449Y1.6801$
N24(0)Z0.1$
N25(1)Z-0.25$
N26(1)Y0.3551C1$
N27(1)X2.574$
N28(1)Y1.6801$
N29(1)X0.449C0$
N30(1)Z-0.15$
N31(0)Z0.25$
N32(9)M30$
END€
If anyone knows how to read Dynapath.
