Net Hasp and Multi Threading
Sandybar
The first thing I do when having SIM disconnect issues is tweak nethasp.ini as follows:
Uncomment and set to the IP address or hostname of the nethasp server:
NH_SERVER_ADDR = IP address or hostname
and set:
NH_TCPIP_METHOD = TCP
If it keeps up, your network interface may be dropping packets while the CPU is under load and is a hardware issue.
The two semi colons make the line they're in front of interpreted as a comment.
Yes, delete them.
Also, by setting the IP address or hostname with NH_SERVER_ADDR you can disable broadcasting as follows, it isn't needed then:
NH_USE_BROADCAST = Disabled
