No feedrate output if previous feedrate is the same.
JohnA
Hi everyone,
It's been a long time since I've posted. I've already searched this topic but the recommended fix didn't work for me. I'm on X4 and I can't get my post to output a feedrate on a toolchange if the feedrate from a previous tool is the same. I know I can change the feedrate and get it to work but I'd like to just fix this, if possible. It works fine with the MPMaster post. Adding the prv_fr=-9999 to my ptlchg post block did not work. Maybe I didn't put it in the right place.
Thanks all,
JohnA
Try this, it comes from the mpmaster post.
ptlchg1002$      #Call at actual toolchange, end last path here
if op_id$ <> last_op_id,
pset_mach #Set rotary switches by reading machine def parameters
if cuttype = 1, sav_rev = rev * m_one #Save the current rev value so Axis Sub doesn't start again at 0 (avoid unwind)
pspindle
whatline$ = four #Required for vector toolpaths
if gcode$ = 1000,
#Null toolchange
else,
#Toolchange and Start of file
if gcode$ = 1002,
#Actual toolchange
pretract
if stagetool = one, prv_next_tool$ = m_one
prv_xia = vequ(xh$)
prv_feed = c9k <--- add this line------
This is from mpmaster.pst
ptlchg_com #Tool change common blocks
if force_output | sof,
result = force(ipr_type,ipr_type)
result = force(absinc$,absinc$)
result = force(plane$,plane$)
pcom_moveb
pcheckaxis #Check for valid rotary axis
c_mmlt$ #Multiple tool subprogram call
#ptoolcomment
if sof & scomm_sav <> snull,
spaces$ = 0
n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
spaces$ = sav_spc
if sof = 0, scomm_sav = snull
comment$
pcomment3
pmisccheck
pcan
if stagetool >= zero,
if omitseq$ = 1 & tseqno > 0,
if tseqno = 2, n$ = t$
pbld, *n$, *t$, "M06", ptoolcomm, e$
else, pbld, n$, *t$, "M06", ptoolcomm, e$
spaces$=0
if output_z = yes$,
preadbuf5
if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
spaces$=sav_spc
pstock
if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
sav_absinc = absinc$
if wcstype > one, absinc$ = zero
pindex
if safe_index,
if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
pbld, n$, pgear, e$
pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfcout, strcantext, e$
if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
if convert_rpd$ = one,
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, pfspindleout, [if gcode$ = 1, *feed], e$
#<------NOTE: *feed (* = force output)
else,
pbld, n$, pgear, e$
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
pfspindleout, [if gcode$ = 1, *feed], strcantext, e$
phsm1_on #must remain before G43
pbld, n$, "G43", *tlngno$, pfzout, scoolant, next_tool$, e$
pcan2 #Added so M and G codes in canned text will output before phsm2_on
phsm2_on #must remain after G43
sav_coolant = coolant$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
absinc$ = sav_absinc
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
plast
