Equivalent FILE/ NEW
ksoufi
Hi Bullines
In fact I'm searching to use an equivalent to FILE/NEW because I h've a problem described below:
_____________________________
dbinit();
Call_to_Function_1(); // open a file, generate some operations, post to a NC file 1,save file1.MC8 file
toolpath_init (TRUE, TRUE, &succf) OR dbinit();
Call_to_Function_2();// open a file, generate some operations, post to a NC file 2,save file2.MC8 file
__________________________________
The problem is that when I open the second MC8 file to check, i find all operations (generated by the 1st Call_to_Function_1() and those generated by the 2d Call_to_Function_2()).It seems that operations haven't been deleeted. I'm testing the OpMgr between the two calls and it's empty!
I don't know why the second MC8 file contains operations generated after initializing the OpMgr? frown.gif
Are you testing toolpath_init() to be certain that it's returning TRUE? Perhaps:
dbinit();
toolpath_init (TRUE, TRUE, &succf);
if (succf)
dbinit();
Sprinkle some calls to OpMgr() for testing purposes. If the test fails, maybe there's another function we should be using or you've stumbled upon a bug.
Of course I'm writting :
// Purpose: delete all operations and/or tools
if (!succf)
cleartextall();
mprintf ("imposible to delete operationsn");
wait_for_space();
return;
OpMgr();
and everything runs fine, the OpMgr is really empty between the two calls but the second file contain all operations!!!!
[ 02-19-2003, 03:23 PM: Message edited by: ksoufi ]
KSoufi,
One thing you can do is call the following:
execute_func("initscrn");
instead of calling dbinit(). There is additional work done inside File/New beyond what is done in dbinit()
NOTE: The execute_func() call gives you access to a multitude of Mastercam functions. See the MILL (or LATHE or WIRE, etc) .TXT file starting at line 9000 to see the character strings that map to certain function calls.
PDG
Impossible!!!!!!!!!!!!!!!!!!!!!!!!
also using
I obtain the same thing :
__________________________________________________
Call_to_Function_1(); // open a DWG file, generate some operations,save file_1.MC8, post to a NC file_1
OpMgr(); // contain 8 operations
OpMgr(); // contain 0 operations : blank
Call_to_Function_2();// open a file, generate 7 operations, post to a NC file_2,save file_2.MC8,
OpMgr(); // contain total operations : 15 confused.gif
Every treatment (file 1 & 2) was tested, there's no problem.
But why even using execute_func("initscrn"); operations still in memory and at the same time the OpMgr is blank between the two treatments
