Modifying Set-Up Sheets
Aaron
To any of you post code gurus out there. I am trying to modify the mill.set file so that it will output exactly which post processor got used by MC to generate the G-code. I think what I need is the character string that maps to the lower left corner of the Job Set-up window that lists the Post that is (was) being used. My current code looks like this (keep in mind that I have not done this before):
ppostname #Post Program Used
??something here to define ppostname??
pmachtyp #Output Machine Type
if ppostname,
if ppostname = "MPMASTER_TAKUMI",
"TAKUMI", e
if ppostname = "MPMASTER_FADAL",
"FADAL", e
if ppostname = "MPMASTER_OKUMA",
"OKUMA", e
#if mi1 = 1, #Takumi Indicator
#"TAKUMI", e
#if mi2 = 2, #Fadal Indicator
#"FADAL", e
#if mi1 = 3, # Okuma Indicator
"Machine: ", pmachtyp, e #Machine Type in Header
As you can see I was using a different approach by directing the set up sheet to look at the misc. integer values. It works, however I want the setup sheet to tell me what Post got used, not which one I think I used rolleyes.gif . I think that I need to define the variable "ppostname" to grab the post that was used from the job setup. Any suggestions or tips??? Or am I trying to see the chicken before the egg?
Thanks in advance.
-aaron-
First you must make sure the PST is requesting the system to create an OPS (Operation Parameters) file.
See this setting in your PST ->
1502. Write operation information to binary file (.ops)? y
# Now you need to declare a string variable to hold the PST name ->
spostname # Declare a STRING variable to hold the PST name
# Now add this code to the PPARAMETER postblock.
(If this postblock does NOT exist in your PST - just add it)
pparameter
if prmcode = 10055, spostname = sparameter # Capture the PST name
# Note that this 'spostname' string includes the FULL path to the PST
[ 02-25-2003, 01:24 PM: Message edited by: Roger Martin from CNC Software ]
