NC FILE EXTENSION by chook
ksoufi
Hi All
in the .pst file post, I've
sextnc (no extension) and in cfg file there's no reponse to question 508. NC Program extension?
When I post (interactively), i obtain a file without extension OK good smile.gif
Now when using
nci_manager(NCIMGR_POST_ALL..) to post my MC8 file and being setting
nc_filename = test for example
Then in the Specify File Name to Write message box MC proposes, by default, test.NC
If Ok button pressed, there are two files created
test.NC empty
and test full
ksoufi,
I don't know if this will help or not. Below is some code I plan on later expanding out to a 'dual post' chook.
It works by first resetting question 91 in a pst file from the mastercam default post processor exe "MP" to the name of the chook. Say in this case "MYMP".
91. Name of executable post processor? MP
to
91. Name of executable post processor? MYMP
Now when 'posting' is called mymp.dll is called instead.
The code passes the arguments to the regular mp.dll and my customized arguments to my setup sheet pst(set) file by calling run_post_exe_dll.
The chook acts differently when called from nci_manager and using the post button in the operations manager. With nci_manager each run of run_post_exe_dll is sent to the default editor. With the operation post button, if edit is set, only the first instance is sent to the editor. I haven't had a chance to play around to see it this is a cfg file setting, pst file setting , or something else.
The nice thing about this chook is that it runs after the nci file is generated. Giving you time to do other things.
Also Make sure 'save nci file' is set or mastercam deletes the nci file after the first run_post_exe_dll and before the second run_post_exe_dll if called.
char temp_nci[FILENAME_MAX];
char temp_pst[FILENAME_MAX];
char temp_nc[FILENAME_MAX];
char setup_sheet[FILENAME_MAX];
//make copy of nci, pst, and nc file names
//post_args are only set when 'posting' and are cleared after
//the first of run_post_exe_dll below runs
strcpy( temp_nci, post_args[0]);
strcpy( temp_pst, post_args[1]);
strcpy( temp_nc, post_args[2]);
//change name and directory for setup sheet
strcpy( setup_sheet, post_args[0]); // nci name with path
reduce_filename(setup_sheet, "", setup_sheet, ""); //nci name only
build_filename(setup_sheet, geo_prefix, "XXX"); //nci name with mc8 file path
//XXX will get striped off by
//the post and replaced by sextnc
//strcat( temp_nc, ".nc.XXX"); //if sextnc is "" will remove XXX and leave .nc
//when run from post button and edit nc is set, this one is sent to editor
//the next instance is not.
run_post_exe_dll( "mp.dll", temp_nci, temp_pst, temp_nc); //post as normal
//setup sheet
run_post_exe_dll( "mp.dll", temp_nci, "U:PostSetupSheet.PST", setup_sheet);
//when run from post button send setup sheet file to editor
