a vb script maybe
There's a script SaveBackup-Mick.zip on the ftp server under vb_scripts directory that will do that.
Do a search on the forum there are several scripts floating around. I believe Rekd did one that backed up to RAR files and James did one to Zip files.
Save a file in two locations at the same time can easily be done, and can be done many ways. In its most simplest form, this can accomplish what you need with very few lines of code:
'// Author: Chris Bellini [email protected]
'// Date: 03/07/2005 9:18 PM
'// File Name: SaveTwice.vbs
'// Description: save a file to two different locations
'// Comments: Modify DEF_LOCAL_PATH and DEF_NETWORK_PATH to suit your needs
' don't forget the trailing ""
Const DEF_LOCAL_DIR = "C:YourDir"
Const DEF_NETWORK_DIR = "M:MappedPath"
' Call the main subroutine
Call Main()
' Purpose: The main subroutine
Sub Main()
Dim strLocalPath ' path to local file
Dim strNetworkPath ' path to file on mapped drive
Dim strFname ' filename
' prompt for filename
strFname = AskString("T (no need to enter the MC9 extension)")
' exit the script if it's an empty string
If (strFname = vbNullString) Then
Exit Sub
End If
' assemble the paths
strLocalPath = DEF_LOCAL_DIR & strFname & ".MC9"
strNetworkPath = DEF_NETWORK_DIR & strFname & ".MC9"
' save the file twice
Call SaveMCAs(strLocalPath, True)
Call SaveMCAs(strNetworkPath, True)
End Sub
Of course, this is a simple example but it's very easy to expand upon this with directory selection dialogs and so on. There's also the backup scripts on the forum and FTP server that Bryan mentioned.
