VB Script Query
Hi there,
I'm asking this on behalf of a local user. He wants to achieve the following:
He wants to manipulate entities in the following manner
Quote:
* As some of these MC9 files were imported from DXF, the layer names have
various names. I need to erase all them and rename Level 1 to HOLDER and
Level 2 to Cutter
* Change the layer of all entities to LEVEL 1 (Holder Profile)
* Change some entities to LEVEL 2 (Cutter profile)
* XFORM-ROTATE all entities about the origin by -90 degrees
* RAM SAVE, deleting duplicate entities
The resulting MC9 File will then be exported to DXF, which VB will support, when I work out how to do it
Unquote.
I would assume this isn't possible, since it isn't possible to change "some" entities to Level 2, as I am sure that VB would have trouble defining "some" smile.gif
This is all a requirement to convert DXF files of tools into Mastercam, and them prepare them so they can be read into Vericut.
'// Author: Chris Bellini [email protected]
'// Date: 03/08/2005 8:29 AM
'// File Name: Mick_at_AxsysCNC.vbs
'// Description: Does a bunch of things that Mick wants when he opens DWGs
'// Comments: Maybe someday it can move "some" entities to Level 2
Const DEF_LEVEL1_NAME = "Holder"
Const DEF_LEVEL2_NAME = "Cutter"
' Call the main subroutine
Call Main()
' Purpose: The main subroutine
Sub Main()
Dim iLevelNo ' level number
' Exit the script if there's no geometry
If Not (IsDrawing()) Then
Exit Sub
End If
' Toast all of the level names and make them visible
For iLevelNo = 1 To 255
' clear the level name
Call SetLevelName(iLevelNo, vbNullString)
Next
' Move all entities to Level 1
Call MoveAllEntsToNewLevel(1)
' Rename level 1 and 2
Call SetLevelName(1, DEF_LEVEL1_NAME)
Call SetLevelName(2, DEF_LEVEL2_NAME)
' Rotate the geo 90deg about the origin
' Note: This function requires a recent version of Mastercam VBS.
' I believe this is included with MR0105. If not, you may need to
' contact your reseller or CNC Software.
Call SelectAll()
If Not (Rotate(0, 0, 0, 90, False)) Then
ShowString "Error: Unable to rotate entities"
End If
' Do a ram saver
Call RunMastercamCommand("ramsaver")
' All done
ShowString("Done!")
End Sub
' Purpose: move all entities to the desired level
' I: the new level
' O: (none)
Sub MoveAllEntsToNewLevel(iNewLevel)
Dim bSuccf ' success flag
' try to get the first entity in the db
bSuccf = StartDBSearch(mc_alive, -1)
' good to go?
If bSuccf Then
Do
If iNewLevel <> GetEntityLevel Then
Call SetEntityLevel(iNewLevel)
End If
' get the next entity
bSuccf = NextDBSearch()
Loop While bSuccf
End If
End Sub
' Purpose: Determine if this there is geometry in this file
' I: (none)
' O: True=valid, False=not valid
Function IsDrawing()
Dim bRet
bRet = StartDBSearch(mc_alive, -1)
IsDrawing = bRet
End Function
Yup, that "some" entities might be tough. As it stands, this script will move all entities to level 1 and they could manually move those "some" entities to level 2. Need more info to attempt to automate that "some", though wink.gif
PS: Your question is similar to this one.
