Here's something that's short 'n' sweet:
'// Author: Chris Bellini [email protected]
'// Date: 04/06/2005 12:03 PM
'// File Name: IncrementAllLevels.vbs
'// Description: Moves entities to a new level based on a user-supplied
'// increment value.
'// Comments: Mastercam currently supports a maximum of 255 unique
'// levels. Mastercam X will support many more
' Call the main subroutine
Call Main()
' Purpose: The main subroutine
Sub Main()
Dim bSuccf ' success flag
Dim iNewLevel ' new level number
Dim iIncrement : iIncrement = 100 ' user-supplied increment value
' Prompt the user for an increment value between 1 and 254. If
' the user doesn't enter a value, exit the script.
If Not (askNumber("Increment value (1-254):", 1, 254, iIncrement)) Then
ShowString "Error: An increment value wasn't entered. Aborting..."
Exit Sub
End If
' Loop through the entire database of entities and move each entity to
' a new level. The new level is the sum of the existing level and a
' user-supplied increment value. Because Mastercam currently
' supports 255 unique levels, any newly summed level number that
' exceeds 255 will not be allowed to contain entities; the user will
' see a nice little error message instead
bSuccf = StartDBSearch(mc_alive, -1)
If bSuccf Then
Do
iNewLevel = GetEntityLevel() + iIncrement
If (iNewLevel <= 255) Then
Call SetEntityLevel(iNewLevel)
Else
ShowString "Error: Unable to move entity from level " & _
GetEntityLevel() & " to level " & iNewLevel & _
". Mastercam V9.x supports a maximum of 255 levels."
End If
bSuccf = NextDBSearch()
Loop While bSuccf
End If
' All done
ShowString "Done!"
End Sub
It'll prompt the user for an increment value and add that to the existing level number of each entity. And if the user enters a value like 220 and an entity is currently on level 70 (220+70=290), the script will warn the user that it can't move the entity to that level since it's greater than 255.
I'll see about ranges.
HTH.
Ok, a bit of a quick hack 'cause I'm lazy but...
'// Date: 04/06/2005 1:16 PM
'// File Name: IncrementAllLevelsWithRange.vbs
'// increment value, within a range of user-supplied levels.
Call Main()
Sub Main()
Dim iCurrLevel ' current level of an entity
Dim iNewLevel ' new level of an entity
Dim iRangeStart : iRangeStart = 1 ' range start
Dim iRangeEnd : iRangeEnd = 254 ' range end
' Prompt the user for an range start value between 1 and 254. If
If Not (askNumber("Range Start:", 1, 254, iRangeStart)) Then
ShowString "Error: A range start value wasn't entered. Aborting..."
Exit Sub
End If
' Prompt the user for an range end value between iRangeStart+1 and 254. If
If Not (askNumber("Range End:", iRangeStart + 1, 254, iRangeEnd)) Then
ShowString "Error: A range end value wasn't entered. Aborting..."
Exit Sub
End If
Exit Sub
End If
' Loop through the entire database of entities, looking only at entities
' on levels in the user-supplied range, and move each entity to
If bSuccf Then
Do
iCurrLevel = GetEntityLevel()
If (iCurrLevel >= iRangeStart) And (iCurrLevel <= iRangeEnd) Then
iNewLevel = iCurrLevel + iIncrement
Else
End If
End If
Loop While bSuccf
End If
' All done
ShowString "Done!"
End Sub
This will prompt for a range of existing levels to move. So if, for example, you want to only move levels 5 through 9 to levels 105 through 109, use this version of the script.
It will appear for every entity that you tried to move beyond level 255. For example, if you set your increment to be 100 and some of your entities are currently on level 180, they won't be moved and you'll receive an error. This is because Mastercam supports 255 levels and the script tried to move the entity to level 280 (180+100=280). And of course, 280 > 255. Fun eh? wink.gif
If worse comes to worse, you can comment out that ShowString() or even toast that ELSE statement entirely; it still won't move the "offending" entity but it won't yell at you either wink.gif
