Chook question
Hi Guys,
I didn't post to this forum since ~ 2 years frown.gif I was really missing this forum. I'm consulting other CAM/CAM forums . This is the BEST smile.gif
I'm developping a chook and wondering if someone can help with this issue. It could be a simple staff !
Using MC 9.1.MR0105 Mill/Router :
looping the DB and seraching for arcs:
db_ptr_type ptr, e_ptr;
ent entity;
get_ent (&ptr, &e_ptr, &entity,ON_SCR_BIT ,A_ID,&succf);
if (!succf) break;
When using the trace to mprintf the center's coordinates; i.e. "entity.u.ar.c[]" It doesn't give the same results as using the menu command : Analyze>Only>Arcs.
I'm not changing the WCS.
Thanks for help
Chris,
The values are exactly the same, just the Y and Z coordinates are reversed. i.e.
Analyze command : X = 1, Y = 2 Z = 3
API function : X = 1, Y = 3 Z = 2
Pete,
basically , what i'm doing i simply importing a parasolid model with holes. Of course it will be loaded in MC as one body and you can’t access features (holes) frown.gif . This is why I’m using the “wire representation” of the solid and use get_ent to sort arcs (circles).
The issue I can’t know in advance in which view these arcs are and so fart can’t use the world_to_view().
I would like simply to emulate the menu command : Analyze>Only>Arcs banghead.gif
Thanks for help
[ 09-01-2005, 10:08 AM: Message edited by: ksoufi ]
"The issue I can’t know in advance in which view these arcs are"
I don't understand. If you've got arc entities, they have the view number stored in them. That's the view number you'll pass to world_to_view(). That is exactly what Analyze does!
Note also, that if Y & Z are reversed, it sounds like the arcs have been stored in Front view
Pete,
The outstanding issue I have is the fact that "entity.u.ar.view" could have a value other than 1 t0 6; i.e. standard views TOP, FRONT, LEFT ...etc. I tested with a solidworks cube with a single hole in the FRONT view. "entity.u.ar.view" returns 10. confused.gif
  • Recently Browsing   1 member
