Making a folder using VB
can someone tell me why this will not work
 If Not FSO.FolderExists("WaikikiMSPrograms" &companyname) Then
Call FSO.CreateFolder("WaikikiMSPrograms" &companyname)
It is suppost to look and see if there is a company name like the one you type in at a prompt, but it just puts another folder with the same name. It doesn't even pop up and tell me that there is a folder already with the same name.
it use to be
If Not FSO.FolderExists("C:WORK" &companyname) Then
Call FSO.CreateFolder("C:WORK" &companyname)
and it worked fine. when I tried to change it to work on network it started happening???
Ok, FileSystemObject does support UNC paths just fine. I wrote this to test:
Const DEF_PATH = "REMOTECOMPUTERSome FolderChris"
Const DEF_DPATH = "connormac"
Const DEF_FNAME = "Test.txt"
Const DEF_FSO_READ = 1
Call Main()
Sub Main()
Dim objFSO
Dim objTS
Dim objNewFolder
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Can we access UNC paths?
If objFSO.FolderExists(DEF_PATH) Then
ShowString "Yup, it's here"
Else
ShowString "Nope"
End If
' Can we create new directories using UNC paths?
Set objNewFolder = objFSO.CreateFolder(DEF_PATH & "" & DEF_DPATH)
If (objNewFolder Is Nothing) Then ShowString "We can create that directory here"
' Can we read files using UNC paths?
Set objTS = objFSO.OpenTextFile(DEF_PATH & "" & DEF_FNAME, DEF_FSO_READ, False)
Do While(objTS.AtEndOfStream <> True)
strTempLine = Trim(objTS.ReadLine)
ShowString "From the file: " & strTempLine
Loop
Set objFSO = Nothing
Set objTS = Nothing
ShowString "Done!"
End Sub
The next thing I'd ask is...do you have permission to create directories in that network location?
Bullins,
Changed
to
If Not FSO.FolderExists("F:" &companyname) Then
Call FSO.CreateFolder("F:" &companyname)
It does the same thing. creates a new folder.
But if I create a folder "TEST" using the VB. Then create the folder "TEST" again it works right. It is like it is not looking at the folders that were already created on the network???
Maybe give me an example with full paths that you want/will be using. Then we'll get this all sorted out wink.gif
'// Author: Mick George [email protected]
'// Date: 16/09/2003 12:58 PM
'// File Name: Creat MS Folfer.VBS
'// Description: Creat MS Folder
'// Comments: '////////////////////////////////////////////////////////////////////////////////
'// Comments:
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
On Error Resume Next
Dim companyname
Dim Program
Do 'ask until a real company name is entered
companyname=AskString("Company Name?")
Loop While companyname="Company Name?" Or companyname="((ESC))" Or companyname=""
Do 'ask until a real program number is used
Program=AskString("Part number?")
Loop While Program="Part number?" Or Program="" Or Program="((ESC))"
If Not MakeFolders(companyname, Program) Then
ShowString "Failed to create folders, aborting script"
Exit Sub
End If
End Sub
' Function Declaration
Public Function MakeFolders(companyname, Program)
' -- Check to see if folders exist
Dim FSO
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- This is kinda long winded but does the job
' -- NOTE: If you use an invalid character for a part number you'll have a problem!
End If
If Not FSO.FolderExists("F:" &companyname & "" & Program) Then
Call FSO.CreateFolder("F:" &companyname & "" & Program)
End If
If Err Then
MakeFolders = False
Else
MakeFolders = True
End If
Right. So in the case of a company already being there, do you end up in the code block that tries to create the folder?
If Not FSO.FolderExists("WaikikiMSPrograms" & companyname) Then
ShowString "If the path to this company's folder already exists, you should not see this message."
FSO.CreateFolder("WaikikiMSPrograms" & companyname)
End If
So let me get this straight. If you have a folder that already exists called:
WaikikiMSProgramsAcme
And then the script gets to here:
' In this example, the companyname variable contains a value "Acme"
End If
It creates a folder called:
WaikikiMSProgramsAcmeAcme
Am I understanding it right?
but it does look like there is a space in front of the folder name I create with the VB. maybe it is the space??? if so how do I get rid of the space
To get rid of leading and trailing spaces in a string, use the Trim() function. So for example:
Program=Trim(AskString("Part number?"))
Better?
