Backup VB script
Make the script look exactly like this:
'// Author: Mick George [email protected]
'// Date: 28/08/2002 02:29 PM
'// File Name: SAVEBACKUP.VBS
'// Description: Example of backing up current drawing.
'// Comments: Original example by Mick George
'// Modified by bryan (_at_) steeplechasetool (_dot_) com
'// Modified by Mick George 7/11/2003 8:30:24 PM
'///////////////// My Constants /////////////////
Public Const fsoDRIVE_UNKNOWN = 0
Public Const fsoDRIVE_REMOVABLE = 1
Public Const fsoDRIVE_FIXED = 2
Public Const fsoDRIVE_NETWORK = 3
Public Const fsoDRIVE_CDROM = 4
Public Const fsoDRIVE_RAM_DISK = 5
Public Const DEF_CENTERED = " "
Public Const DEF_ERRLOG = "C:McScriptErr.log"
Public Const DEF_BACKUP_DIR = "C:mcamxmcxMillback up" ' -- Edit to your taste
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
On Error Resume Next
Dim strBackupPath
Dim strOriginalPath
Dim FSO
Dim strYear
Dim strMonth
Dim strDay
Dim strHour
Dim strMin
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- Make sure theres a disk in the floppy drive
'// If CBool(CheckDrive("A:")) Then
' -- Check to make sure backup folder is valid
If FSO.FolderExists(DEF_BACKUP_DIR) Then
' -- Make sure we have a drawing to save
If Not IsDrawing Then
ShowString "No current drawing" & DEF_CENTERED
' -- Bail
Exit Sub
End If
' -- Store current drawings name
strOriginalPath = GetCurrentFileName
'' ' -- Assign a new Mc filename
'' '//strBackupPath = "A:Backup.MC9"
'' strBackupPath = "C:TEMP"
' -- Format a time and date stamp and strip illegal chars
strYear = Replace(FormatDateTime(Date, vbShortDate), "/", "")
strHour = Replace(FormatDateTime(Time, vbShortTime), ":", "")
'' strYear = CStr( DatePart( "yyyy", Date ) )
'' strMonth = CStr( DatePart( "m", Date ) )
'' If Len(strMonth) < 2 Then strMonth = "0" & strMonth
'' strDay = CStr( DatePart( "d", Date ) )
'' If Len(strDay) < 2 Then strDay = "0" & strDay
'' strHour = CStr( DatePart( "h", Now ) )
'' If Len(strHour) < 2 Then strHour = "0" & strHour
'' strMin = CStr( DatePart( "n", Now ) )
'' If Len(strMin) < 2 Then strMin = "0" & strMin
' -- Build fullpath
''strBackupPath = AddBackSlash(DEF_BACKUP_DIR) & FSO.GetBaseName(strOriginalPath) & "." & strYear & strMonth & strDay & "_" & strHour & strMin & "." & FSO.GetExtensionName(strOriginalPath)
strBackupPath = AddBackSlash(DEF_BACKUP_DIR) & FSO.GetBaseName(strOriginalPath) & "." & strYear & "_" & strHour & "." & FSO.GetExtensionName(strOriginalPath)
Call ClearMenuAndPrompts
' -- Display current file in prompt area
Call WriteString("Backing up file, please wait...")
If SaveMCAs(strBackupPath, False) Then
'//ShowString "File backup to floppy drive successful" & DEF_CENTERED
ShowString "Backup to " & DEF_BACKUP_DIR & " complete" & DEF_CENTERED
Else
ShowString "Could not backup file to " & DEF_BACKUP_DIR & DEF_CENTERED
End If
' -- Switch back to original file
'Call SaveMCAs(strOriginalPath, False)
Call SaveMCAs(strOriginalPath, True)
Call RepaintScreen (True)
Else
''ShowString "Please insert a disk into drive A:" & DEF_CENTERED
ShowString "Folder " & DEF_BACKUP_DIR & " does not exist!" & DEF_CENTERED
Exit Sub
End If
If Err Then Call TrapError("Sub::Main", Err, True)
Set FSO = Nothing
End Sub
' Sub Declaration
Sub TrapError(sSource, objErr, bLogIt)
Dim sMSG
Dim sLogError
Dim FSO
sMSG = "Following error occurred in this script:" & DEF_CENTERED & vbCrLf & vbCrLf
sMSG = sMSG & objErr.Description & DEF_CENTERED & vbCrLf
sMSG = sMSG & "Number: " & objErr.Number & DEF_CENTERED & vbCrLf
sMSG = sMSG & "Source: " & DEF_CENTERED & sSource
ShowString sMSG
If bLogIt Then
sLogError = "Error " & objErr.Number & " in " & sSource & ":" & vbCrLf & objErr.Description
Call WriteLog(sLogError)
End If
objErr.Clear
Set objErr = Nothing
End Sub
' Sub Declaration
Sub WriteLog(sLogMessage)
Dim FSO
Dim fsoStream
Set fsoStream = FSO.CreateTextFile(DEF_ERRLOG, True)
fsoStream.WriteLine String(78, "-")
fsoStream.WriteLine "---" & FormatDateTime(Now, vbGeneralDate) & "---"
fsoStream.WriteLine sLogMessage
fsoStream.WriteLine GetScriptEngineInfo
fsoStream.Close
' -- Clean up
Set fsoStream = Nothing
Set FSO = Nothing
If Err Then Call TrapError("Sub::WriteLog", Err, False)
End Sub
' Function Declaration
Function GetScriptEngineInfo()
Dim s
s = "" ' Build string with necessary info.
s = ScriptEngine & " Version "
s = s & ScriptEngineMajorVersion & "."
s = s & ScriptEngineMinorVersion & "."
s = s & ScriptEngineBuildVersion
GetScriptEngineInfo = s ' Return the results.
If Err Then Call TrapError("GetScriptEngineInfo", Err, True)
End Function
Function CheckDrive(sPath)
Dim FSO
Dim fsoDrive
' -- Get the "A" drive
Set fsoDrive = FSO.GetDrive(sPath)
Select Case fsoDrive.DriveType
' -- Only interested in a Floppy drive...
Case fsoDRIVE_REMOVABLE: CheckDrive = fsoDrive.IsReady
Case Else
' -- Force failure
CheckDrive = False
End Select
' -- Clean up
Set FSO = Nothing
Set fsoDrive = Nothing
If Err Then Call TrapError("Function::CheckDrive", Err, True)
End Function
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
I'm also assuming that you have the rights to create files in C:mcamxmcxMillback up and in the root of C (C:).
