Mirror with VB script
I am making a VB script for version 9.1 and I need to mirror in the script without hard-coding "xfmmir" and asking the user for entities. Is their a code in the script that I can use to mirror without any user input. I need to mirror two levels with different colors on each level. I think I can get the selection code to work if I could get a function to mirror. If I could override the user prompt for entitiy selection I could still use the hard code and select what I need in the script in a sub. I also would like to have a "full" list of functions to use in Mastercam script. The html that comes with the software is lacking functions that I have seen in some of the sample programs. If anyone has this PLEASE post it on the FTP. Thanks for any help.
There's no way to use the mirror (among many others) functionality itself; only the one that uses the dialog via the RunMastercamCommand() sub. You'll have to manually mirror the entities yourself. It would look similar to this:
Call Main()
Sub Main()
Dim iCurr ' entity pointer
Dim bSuccf ' success flag
Dim objLine ' McLn object
Dim objArc ' McAr object
Dim objPoint ' McPt object
Dim iLvl ' level of the current entity
Dim iColour ' colour of the current entity
' Start searching the database by getting the first entity.
bSuccf = StartDBSearch(mc_alive, mc_arctype Or mc_pointtype Or mc_linetype)
' Loop through the database of entities and manually mirror and you see fit.
Do While bSuccf
' Get the current entity pointer.
iCurrEnt = GetEntityEptr()
iLvl = GetEntityLevel()
iColour = GetEntityColor()
Select Case GetEntityType
Case mc_linetype
Set objLine = New McLn
If GetLineData(iCurrEnt, objLine) Then
' Mirror line about the axis of your choosing.
End If
Case mc_arctype
Set objArc = New McAr
If GetArcData(iCurrEnt, objArc) Then
' Mirror arc about the axis of your choosing.
End If
Case mc_pointtype
Set objPoint = New McPt
If GetPointData(iCurrEnt, objPoint) Then
' Mirror point about the axis of your choosing.
End If
End Select
' Get the next entity.
bSuccf = NextDBSearch()
Loop
End Sub
Since you're looking for certain levels and colours, you'd want to put that SELECT inside of some logic, like an IF, to only do so when the current entity matches the colour and level that you want.
Since you're running V9, you're in luck. Take a look at McLangDef.csv in the root of your Mastercam directory (Ex: C:Mcam9McLangDef.csv). I've found more in there than in VBScript.htm.
Thanks Bullines. I've been teaching myself VB as I go trying new things each time and using examples for refrence. I am making a script to layout geometry on a flat piece of steel for the manual mill guys to follow when roughing. I have a spring loaded pointer in a mill and I need to scribe the shape on several pieces per job. I use color and level to determine which piece gets which geometry. I have my script made to : ask for file/ change levels by entity color/ (I need mirror here for two levels only)/ toolpath one op per level with group name/ post each op to a seperate program with it's own nci destination(still working on nci)/ save file when done. I have been writing subs and then adding to the program as I go. Mick's examples in the VB folder of V9 have been a big help.
