Here's what I posted in the X Beta forums a couple of months back:
Getting started with Nethooks is super simple. I'm a fan of C# so I'll use that to explain. You'll first create a Class Library project in Visual Studio; C#, VB or J# (does anybody actually use J#?!?!?). Then you'll want to add a COM reference to nethook.dll (it'll be in the root directory fo wherever you installed X). You'll then want to add this to your class's using section:
using Mastercam;
Next you'll have to make the class you (or more specifically, VS .NET) created extend the CMCNETApp. So change this:
public class CTheClassYouCreate
to:
public class CTheClassYouCreated : CMCNETApp
Instead of a main() method as the entry point, you have to add an ovverriden method called Run() to your class:
public override MC_RETURN Run(System.Int32 param)
return MC_RETURN.MC_NOERROR;
Build it and you should be good to go. So for a HelloWorld Nethook:
using System;
using System.Windows.Forms;
using Mastercam;
namespace HelloWorld
public class CHelloWorldNethook : CMCNETApp
public CHelloWorldNethook()
MessageBox.Show("Hello World!");
And like Roger mentioned, check out what's available to you in nethook.dll in the Object Browser. HTH
I can whip you up a VB.NET version, if you wish. It basically comes down to replacing C# synatx with VB.NET (Ex:"using" -> "Imports", "override" -> "Overrides", "Implements" when subclassing, etc).
Speaking of real "C" hooks (not C# or VB), I have few observations/questions.
I used the stub generated by the c-hook wizard without any modification, and it did not run: the message box mentioned the incompatible version number. So I created a small driver, loaded one of the provided c-hooks, called "m_version" function, and there it was: the version number should be 1001, but the macro C_H_VERSION has the value of 1000. I suppose the 1001 means version 10, service pack 1, but the SDK files have not been updated. Or is there a newer SDK, which I have not got yet?
My second observation is that when the dummy c-hook (with modified version number) terminates, the DLL is not unloaded properly, and is still locked. Is this a feature that would speed up subsequent loading, and if so can it be disabled? It is a big problem during the development, I can not rebuild it without shutting down the Mastercam.
Marko
If you replace your m_verion routine with this -->
Your CHook will run on ANY version of X.
Note that this may not always be desirable !
IF your CHook requires a specific release !
extern "C" __declspec(dllexport) int m_version (int version)
int ret = C_H_VERSION;
// Allow chook to run in any version of mastercam that has
// the same major version
if ( (version / 100) == (C_H_VERSION / 100) )
ret = version;
return ret;
As for the termination issue, you can try this -->
In your m_main replace the return MC_RETURN; with return MC_UNLOADAPP;
Note that is will have no effect if your CHook is loaded via an .FT file (Function Table).
Read... Your CHook DLL will not unload.
