OK Guys and Gals,
I have a prototype part that has 7 different operations. I programmed it a few months ago using a proven post. That particular version of my post did not use VB scripts. Now we are producing a large quantity, so I need to post it for all machines. The multi-post VB script that I am currently using won't work on Operation 1, but will work on the other operations. I have 5 different VB's and in this 1 program the VB's won't even run. Not only that, when I try to produce a set-up sheet using mill.set, the set-up sheet will come up but MasterCam closes itself. Hope this makes some kind of sense. I cannot see anything obvious about this operation that causes these problems. Have any of you encountered this type of problem? All input is greatly appreciated! smile.gif
yes that works. Plus Mick has helped me with some create folder VB's that work while I have this program up. the only diffrence I can fell is the create folder doesn't have this line
' -- Check for drawing
If IsDrawing Then
Could it be something about the drawing?
The IsDrawing() function determines if you have a valid MC9 open. The MC9 is considered valid if it contains at least one entity (line, arc or point). If IsDrawing() returns False, then the script packs it in and calls it a day.
' Sub Declaration
Sub Main()
'On Error Resume Next
If IsDrawing Then ' <- if this fails, the nothing else in the script is executed
Dim companyname
Dim Program
' and so on...
So another test on that file could be this:
Call Main()
Sub Main()
If (IsDrawing) Then
ShowString "Hello Mastercam VBS World!"
End If
End Sub
Function IsDrawing()
Dim bRet
bRet = StartDBSearch(mc_alive, -1)
IsDrawing = bRet
End Function
