(sorta) OT: VBS Language Question
Just throwing this out there...
Does anybody know of a VBS equivalent of the 'continue' keyword in C/C++/Java/etc to go to the next iteration of a loop? VB has never had it but I could fake it by throwing in a "zip nada nothing" block before the end of the loop like this:
Do While (bSomeCondition <> False)
' do some stuff
' do some more stuff
' this might be by itself or nested really deep so that Exit won't work
If (bFreakyCase = True) Then GoTo ContinueLoop
' do even more kewl stuff
' mimic the continue keyword of C/C++/Java/etc
ContinueLoop:
Loop
But for some reason, VBS hates my GoTo. I know that GoTo's are bad programming practice and all, but that was pretty much the only time I ever needed them (thanks VB wink.gif ). Is the GoTo statement depreciated in VBS now...like really depreciated?
pip, I want to continue iterating and not bail on the loop (which is what wend's and until's will do).
Matt, I get a "statement expected" type of error. This happens external to Mastercam, too. Load up this code in notepad and save it as whatever. Then run it.
Dim nCount
For nCount = 0 To 20
MsgBox nCount
' 13....oooh, scary...let's skip it
If (nCount MOD 13 = 0) Then GoTo ContinueLoop
ContinueLoop:
Next
Yes, I know that something like this would do the trick:
If (nCount MOD 13 <> 0) Then MsgBox nCount
Next
But I just wanted to illustrate it. Put my first snippet into, say, VB6 and you'll see that it works fine.
Mastercam's VBS interpreter produces a similar error. That's why I'm thinking that Microsoft depreciated GoTo in VBS to the point that it's un-usable.
None that I know of but then vbscript isn't my language of choice. You'll probably have to restructure your code or use some kind of fake do..loop tied in with a continue variable. frown.gif
pseudo code
do loop1
continue = true
(fake) loop2
if something break loop2
do loop 3 while continue
if err, continue = false; break loop3
loop3
do loop4 while continue
if err, continue = false; break loop4
loop4
break loop 2
loop2
loop1
Bryan, your psuedocode snippet is completely and totally hideous, and I mean that in the nicest possible way wink.gif
There is no 'break' statement in VBS. Either way, a break would exit the loop entirely. A 'continue' statement just skips the current loop iteration and moves on to the next one. If you know some C/C++, check this. Even if you don't, check this wink.gif
for (int i = 0; i <= 20; i++)
if (i % 13 == 0) // 13 is too scary to print
continue;
cout << i << " ";
This is a very basic example. This loop will attempt to print the integers running from 0 to 20. What happens here is that when the loop comes across a value of i (between 0 and 20) that is evenly divided by 13 it executes the 'continue' statement. 'continue' statements essentially skip any following statements and move to the next iteration of the loop. So when i = 13, it evenly divides into 13, and the loop skips the call to cout and goes to i = 14. I know that this example is very easy bypass printing 13 with a simple 'if' statement, but 'continue' is very handy when you have plenty of nested logic statements and want to "skip" an iteration. So the following is the result:
0 1 2 3 4 5 6 7 8 9 10 11 12 14 15 16 17 18 19 20
Conversely, if I used 'break' instead of 'continue', the loop would end and 14 to 20 wouldn't be displayed. The result would look like this:
I'm bummed that I can't fake the 'continue' keyword in VBS like I could in VB, but I'll get over it (already have, actually, after some refactoring). There's always plenty of ways to accomplish something wink.gif
almost seems like you need to evaluate everything
by putting a
If
end if
Please let me know how you handle this problem because I want to learn this too. Thanks
That's pretty much what it came down to. A little bit of a change of flow and subsequent refactoring and I'm back to the task at hand. Not as clean as I imagined but it's not that bad and I would probably have to go back to the drawing board if I were deep inside of logic statments but I was only two levels in, which isn't bad. So I'm not complaining wink.gif Good on Microsoft for axing 'goto' but I would like to see a 'continue' at some point, for those times when I'm in a logic swamp wink.gif The 'continue' quandry even forced me to take a look at a class that I wrote and I managed to trim some members that I thought I needed but realized I didn't wink.gif Two birds with one stone smile.gif
